I have an R33 GTS (non-turbo) that has been written off due to being t-boned. Although the car is not worth getting fixed the damage is not actually that extreme and only the rear quarter panel and suspension has been taken out. All the rims are still okay and everything else inside and out are in good condition.
The car has done 128000ks and the engine is in perfect working order, as is the gearbox. All gears work perfectly. This is an ideal buy for someone needing parts!!! Comes with everything except for the dash. All I want it $1500, the gearbox and engine are worth well over that alone.
Anyway looking at $1500 ono for the entire car as is. I do not have the time to remove the engine or gearbox so I am just selling the entire car for $1500 ono!
The deal is you have to come and pick the car up which will require you to tow it away.
No interstate buyers please!
I AM NOT SELLING ANY PARTS!!!! JUST THE CAR AS IS!!!!
http://www.skylinesaustralia.com/forums/in...t&id=130300
http://www.skylinesaustralia.com/forums/in...t&id=130302
http://www.skylinesaustralia.com/forums/in...t&id=130303
Edited by MSPEC
https://www.sau.com.au/forums/topic/208102-wreaked-r33-gts-1995-s1-1500/
does it run?
will it include wheels.
is the ONLY things missing the dash and suspension?
if so , i have someone very very interested
and looks more like drifting gone wrong not a t-bone accident!
does it run?
The engine runs yes, it includes everything!
is the ONLY things missing the dash and suspension? - YES
and looks more like drifting gone wrong not a t-bone accident! - My sister is not really into drifting and I assure you she was t-boned.
  • 1 month later...
your links don't work.... think they are missing the part between the "in" and the "t"...
Not sure why they don't work for you but I just clicked on them and they are working fine!
did it bend all the floor where the suspension was riped from? or did it just rip it off?
Anyways $1200 and i can pick it up this weekend.. No messin round, just Cash...
Let me know ASAP and i will put in a $250 deposit.
Cheers
webber..
Also i can't PM you so, can you put up a mobile number? Cheers
I just PM'ed you my mobile number. Why can't you PM me?
did it bend all the floor where the suspension was riped from? or did it just rip it off? - just riped off.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
