Hey Guys,
I have recently imported this Drift Spec Sil80, which I was inteding to use for drift.
However working 55hours a week has left me very little time to do anything else.
I'm after $12,000, or swap for a Manual R33 Gts-t
Nissan SIL80
1993
SR20DET
82,000km
5speed Manual
WITH VERY LONG LIST OF MODS:
*S13 Silvia front conversion
*Custom Purple Pearl Paint Job
*Aero Spec Side Mirrors
*Zeal Coilovers
*Roll Cage
*17Inch Work Wheels
*Aftermarket Fuel Pump (brand unknown)
*Re-maped ECU
*HKS 2560 Turbo
*Aftermarket Exhaust Manifold
*SARD fuel regulator
*Nismo 550cc Injectors
*HKS Front Mount Intercooler
*3inch Exhaust System including dump pipe and high flow cat, with twin cannon mufflers.
*Blitz Dual Stage Boost Controller SBC i-D
*Nardi Steering Wheel
*Apexi Tacho Meter
*Various Greddy Gauges on passanger side
*Bride Drivers Seat
*Heavy Duty Clutch
*Short Shifter
*Full Body Kit, (unsure of brand/type)
*BLITZ blow off valve
*BLITZ airpod
*Aftermarket Oil Cooler
*Aftermarket Radiator
PLUS THERE ARE PROBABLY MANY OTHER BITS I MISSED
I'm running the turbo on a very conservative 1.2Bar at the moment, at which it made 242rwkw
Its currently uncomplied, but I have all import papers so it CAN be complied.
Here's just a pic taken on my phone, i'll take some more tomorrow.
https://www.sau.com.au/forums/topic/208199-drift-sil80/
Is it and can it be complied??
It CAN be complied, it was imported through raws, not CAMS (race-use only)
which means I have import approval and all paperwork, so it CAN be complied and road registered.
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3738522
ignore that it helps if i read the whole post lol, how much for compliance any internal work ??
depending on which raws workshop you use, but the ones in sa all charge around $3000
and the car needs to be as standard as possible, so it would involve a bit of work, which if done by a workshops wont be cheap!
Thats why its best suited as a track car
or it would suit someone that has all the standard parts and a bit of time on their hands to do the work themselves.
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3738534
It is possible to make the car standard your self, and then give it to them..
Have a search you might be able to do everything, then get them to tick the box's.
Just trying to get a hot car a new home....lol
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3739697
yep all the work can be done yourself, and then just give them the car as standard as possible to comply
It can get complied as a sil80, so the lights, fenders and bonnet do not have to be changed.
Edited by Tommmo
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3739890
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
