I doubt I went over 100, so my guess is on just below 30km/h over the limit.
I just had a look at the Perth Road Safety website, and it says 25-40km over the limit = is now a $750 fine??? and increased to 5 demerit points?
Can anyone confirm this? How much am i looking at?
My first speeding fine in 2 years; maybe it was a good thing I got caught =(
https://www.sau.com.au/forums/topic/208219-rougly-30km-over-limit-fine/
OK NVM, those are the new penalties starting from March 1. But I have a question, if the fine is processed at a later date and arrives AFTER March 1st, it will still be under the old penalty as the incident happened before right?
More than 29 km/h but not more than 40 km/h
Was $350 Now $700
o_0
what's the web add for the perth road safety where you checked? i tried the obvious but nothing came up
http://www.officeofroadsafety.wa.gov.au/in...topicsPenalties
Note they are the NEW penalties which come into effect on the first of March.
Edited by Meecrob
I've always thought you lose your license for a period if its over 40 or 45, not sure. Can anyone back this up?
Im very sure its 45 and over is loss of licence. I got done for wreckless and on the summons it said exceeding 45+
Yeah I guessed it was that much because I remember Perth having much lenient speeding fines as opposed to the other states.
So can someone confirm that around 30km does NOT equal to a loss of license?
Oh yeah before someone flames me for speeding, there was no cars on both lanes, and it's so rare for me to speed =(
you have over 3 months till you recieve your fine any way so stop stressing
Man to be honest I don't care about the fine at all; I'm more concerned about the loss of license IF that is the case.
Does anyone know for sure if 30k over results in a suspension of your license? Even for 1 month?
You wont lose it for 30 kmph over. . just a fine and points
45 and over is wreckless/dangerous and points and fine and court and cought fees lol
Thanks dude, just what I wanted to hear.
I think I was still lucky that I didn't end up flooring it completely or had my car been faster xD
Thanks guys for the answers!
think it's 150 n 3 dermerits still
don't think the new thing has kicked in yet ?
I''m not 100% sure whether i was below or exeeding 29km/h, thats a $100 difference.
As for a $150 fine, I'm not sure where you got that but if thats true that even better =D
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
