All right, i have a series one rb25det with a timing issue i cannot figure out-looking for help. This problem only happens under load, from 5800-6300 rpm. With a nissan consult diag computer connected i can watch the computer go from 33-40 degrees btdc ignition timing to 0 degrees at 5800 rpm, and the motor runs like shit, then after stumbling up to 6300 it gets all the timing back (33-40 degrees) and pulls hard to 7000. Now i was also able to monitor all the other sensors and they are all reading properly and in spec in that range. I have also just recently taken care of the coil misfires i was having so i know that that is not the cause, plus fuel trim in that range does not reflect any sort of ignition misfire-it just pulls all the timing out and runs like shit till 6300 then pulls hard. Now i know that knock is usually the cause for an ecm to pull timing out, but i cannot monitor knock on any of diagnostic computers i have available to me (including the nissan consult). Please if anyone has any idea or has heard of this let me know! Oh and by the way, the motor is mostly stock, just 3" full exhaust with no cat, fmic, and 10 psi boost. -Thanks
https://www.sau.com.au/forums/topic/208244-rb25det-pulling-timing-please-help/
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
