because most R33's with RB25 engines are running near max voltage after 200rwkw.
at 220 that you want, they will be past their resolution.
and series 1 to series 2 AFM are slightly different. but still max out at the same level.
you are changing the afm. might as well start with the right one instead of having to change it again in the future.
my car is making ~250rwkw on the stock afm :(
  • 3 weeks later...
that's why I said most.
and did you tune it?
did you see it being tuned?
do you have a PFC hand controller where you can see the AFM voltage?
is it not hitting max (4.8 or whatever it is) way before redline?
You can tune the car still once it has passed max voltage..
but it's not as accurate.
which kinda defeats the purpose of having an AFM equipt car..
and it is kinda in the zone where you would want to place the most emphasis on getting the tune right.
  • 3 weeks later...
  • 3 weeks later...
from wat i have read on here the R33 s2 pins , 2 of then are for grounding ! can anyone comfirm !
No thats not correct.
The S2 pink label R33 AFM has 3 terminals. With the AFM facing towards you and the flow arrow pointing ===> they are:
pin 1: 12v from eccs relay
pin 2: Ground
pin 3: Signal
The Green label R33 S1 AFM however uses 2 grounds. The first is an ECU ground, the second is a Chassis ground. This is the same scope and dimensions as a rb20det silvertop AFM, the terminal outputs are slightly different but both 80mm.
Here is something a found on the net ages ago that I dig up when I need it:
Edited by James_03
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
