Hey guys i am a bit confussed about complience under the new import laws.
how mush is to complie a r33.
i have been told $4000 and other say they can do it for $2000
anyone in Melbourne who can do it for $2000 plz tell me
is more of less for GTST model compared to GTS(n/a)
Becasue the importer whats to sting me $4000 for my n/a
but if i can get it cheaper he will take $2000 of the price :D .
Cheers.
https://www.sau.com.au/forums/topic/20830-complience-costs/
SEVS is used to determine if the vehicle is eligible to be imported, where a RAWS has to import/comply the vehicle. Was supposed to be implemented 8th May, not many people have gained licenses (too many are waiting for someone else to cough up the cash for testing etc., then copy them!).
https://www.sau.com.au/forums/topic/20830-complience-costs/#findComment-437854
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
