SOLD
Item: HKS GT-RS turbos, genuine HKS bridged manifold, custom Earls water lines and fittings, Apexi 136mm thick drag intercooler, custom stainless intercooler to plenum pipe, Greddy polished plenum
Age: All less than 5,000 km (with the exception of the manifold which was used when I bought it)
Condition: Excellent
Price: $3,000 plus postage
To Fit: R32 GT-R
Contact: PM
Comments: See below
This is one serious low mount package that can feed (and cool) enough air for 600 rwhp and a 10second pass. I spent a LONG time getting this together and developing a monster street/strip setup. The only reason that I changed is my latest fad for track and motorkhana which requires a completely different and lower power set-up.
The above parts are less than 5,000 km old and are in great condition.
OK - let's start with the turbo side of things.....
The GT-RS terbs are well known for big power applications. These are in great condition as evident by the unworn compressor turbines as seen below:
Note that these also have brand new actuators fitted.
What is not so well known is that these terbs are prone to "shuffle" at part throttle. Using a bridged type manifold helps greatly in reducing this.
The bridge also fouls the standard factory water coolant lines, so I had Earles lines and fittings made up as shown in the first pic above.
Now - onto the intercooler. This thing really is a monster and it's a shame that Apexi have stopped making these bar and plate units. This is in basically new condition and comes complete with blow off return pipe (replaces the small factory plastic tube).
I really can't say much more except this has a 600x280mm front area with a massive 136mm thickness:
To ensure maximum airflow, we made up a stainless connector from the intercooler to the 100mm Greddy plenum. This includes a vent pipe to connect to the Apexi blow off return pipe:
And finally the Greddy plenum. This has been highly polished and is in perfect order:
I really prefer to sell this kit as a whole, and for that reason I won't split this up unless I really have to. When/if I do split this, the separate prices will total much more than $3k I can assure you (have offers already in Perth for IC and terbs).
The sale price of $3,000 is excellent value and with the addition of some silicone joiners, clamps and gaskets, this is a straight bolt on affair.
Prefer local pick-up but will pack and send at cost to anywhere in Oz.
Contact by PM.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
