I got hold of some M-type front brake for my 32. but i just got the calipers and rotors and a few fitting that go with it....
this is from http://www.skylinesaustralia.com/forums/R3...ml&hl=brake
To do conversion:
a) type-m 4pot caliper x 2
B) type-m brake lines and all fittings x 2 (mandatory!) <----------------------------------- ZOMG! My lines were cut!!!!!
c) type-m spec discs, which will generally be much thicker than the non type-m
d) brake fluid bottles x 2 (DOT 3 or better rating) - supercheap auto
e) brake bleed kit (supercheap auto)
"In a way this is one of the more fiddly parts of the process. Make sure you have the type-m lines or equivelent, as the non type-m have a different thread pattern on the caliper end and WILL NOT work (trust me I tried)"
So that means i need M Type lines from somewhere?
has any1 done this conversion b4, any help would b appreciated!
https://www.sau.com.au/forums/topic/208538-oh-noes/
Maybe try somewhere like Pirtek, I think they come out too but charge a call out fee or alternatively just take your parts in and see what they can do for you.
Failing that finding a wreck somewhere. Btw, what sort of $$$$ does it cost to upgrade just out of curiosity.
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3688537
ive got a set off R33 type-m brake lines from my s2 R33 4 door GTS25T type-m 1996 i upgraded to braided i can sell em too you how much you want to offer for them
P.S the 4 door brake lines are the same az 2 door upto ypou bud will the r33 lines type-m fit the r32 type-m brake calipers.?
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3689254
wat group buy section? is their a group buy thread on brake lines?
i was just thinking of taking it into my mechanic and getting him to fix it up. but id love to solve this problem @ home :S
Edited by joeleo87
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3691180
yeh thats just the lines... i cant find my effen camera atm. ill post some pics tomorrow. the calipers still have the 'm-spec' lines goin into them but they are cut further along the lines... so just past where the bracket sits, so i was thinking of just trying to undo the hose at 1 of the connection points and try and fit my hose in there.
*edit - Thanks for the link tho Evil, i need all the help i cant get :D*
Edited by joeleo87
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3691294
