Hey guys, went with Steve last night to take some nice photos of my car, got some good shots so I thought I'd share with you all...
Cheers to Steve for providing the camera and the camera work, any criticisms, give them to Steve :D
Edited by heslo
https://www.sau.com.au/forums/topic/208564-weekend-photoshoot/
Nice pics and tough car to go with them! Use the IMG & /IMG tags if you want to embed them, but you probably knew that already :D
I like the SKYLINE lit up on the back - looks bloody good! Would like to see how it's done.
Edit: looks like they're embedded now :P
Edited by 32godzilla
Do cops pick on ya if you have the skyline thing lit up or do you just have it off around cops? seen the DIY thread on this and wasn't sure if the cops take this as being defectable or not, any idea?
is there a different garnish to buy because i was looking at mine to do the same and i cant see how u can just get the letters to light up looks killa cant see how cops can get u seeing its a red light but they can do u for anything these days :)
have you checked out the DIY area? they got a thread about how to do it if ya interested.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
