Four 16x7" wheels with tyres. Off my R34. 5 stud pattern with nissan logo in the middle, fronts are about 50%, one rear about 75% & the other is a brand new tyre.
Im going to advertise them for sale on a couple of places but need some honest opinions on how much to advertise for exactly as I dont really know.
Thanks people!
they don't really offer any benefit over the stock R32 or R33 wheels.
0.5 inch wider is the only benefit (but makes no difference as you can't put a larger tyre on it anyway.)
so unless someone likes the style you wouldn't get any more than what stock R32/33 wheels go for.. about $300 with tyres.
and the tyres you have aren't all new and having one new and one older will probably not be road worthy being on the same axle.
unless the tyres are an expensive tyre to begin with (as in some sort of semi slick or at least a top shelf street tyre) then maybe you could ask for more..
Does the non turbo R34 have 4 piston brakes?
if not, the offset of these wheels might not suit turbo skylines with the larger brakes.. might want to check that out..
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
