What are all specs of the bike?
Suzuki GSX1300 R Turbo 2000 model
What turbo (Specs of both wheels and wastegate)? Motor internals, is it still high comp with standard pistons or is it forged?
Runs a garret t28 same as found on the Nissan Silvia
What cams, crank rods, etc?
Stock cams stock crank and stock rods
Extended swingarm?
I have one 4 inches over for it but not on the bike will get sold separately
What boost, I see you state it is running 8psi? Is it laggy?
It runs off 4lb wastegate spring and off a boost controller it has 4 lb boost in 1st gear 6 lb
boost in 2nd gear and 8 lbs boost in 4th 5th and 6th gears. Laggy I don't think so
What exhaust, just a dumpy style off the turbo with no muffler?
It runs a full system with muffler I tried my best to make it a sleeper
What air filter?
K&N
Injectors standard?
Yes good for 300 HP
What tune has been done to the bike?
Dyno tune as the dyno chart states
and lastly what brake pads, discs etc and why was the colour changed, due to a drop? How does it cope with chains sprockets due to such high hp?
It has race pad and braided lines all round duals on front single rear line and also a braided clutch line
Colour change was due to the fact I bought a red black roller and was going to do a drag bike with it but decided against the whole dragging notion I always liked the red/black scheme so I did a fairing swap and sold the blue / silver roller hence why the colour scheme is a 99 model and the frame is a 2000 model To my knowledge the bike hasn't been on the ground
How many kms on the frame/suspension/motor? condition?
31*** ks at the moment motor is great like I said I had just pulled it apart and rebuilt the top end
Is the frame straight?
As straight as it came out of the factory
The bits you didn't ask for when you turbo a Busa the stock motor will be good for 320 RWHP after that the pistons and rods will start to go after around 400 RWHP time for a new crank. This runs a safe 250RWHP on a decompressed engine. The reason I had to rebuild was due to my own laziness and not retensioning the head when I bolted the turbo on .I believe the head gasket went on it at the first Dyno session when it was getting mapped and it still made its 250RWHP Then when you ad a turbo you must add strong clutch springs to hand on otherwise it just slips once you do that you need to strengthen the sprocket cover so the clutch push rod doesn't blow it out I have put a billet sprocket cover on it and it also works as a case protector. I have also put a brand new OEM clutch pack in it at a cost of $450 and it has never been down the ¼ with this clutch pack. The tyres are going ok but I think that's to me being a soft cock and not flogging it all the time The chain and sprockets are all good but will wear quicker than if it was stock powered
The blow off valve I have put into the ram air tube so it isn't visible from the outside it runs an intercooler under the tank which is probably good for 10rwhp over a stock plenum
I put decent Auto meter Pro Comp Gauges in it for the boost and fuel pressure
It uses a rising rate FMU for the fuel and a Bosch 040 fuel pump only 12 months old, as is the Fuel filter
The bike rides like a stock bike but when you hit the throttle you know it aint stock it has a PC11 and the frame and swing arm are polished
That is all I have for now cheers.
if you need to know anything else just ask I have nothing to hide
click this link for the turbo install pics if you like Install pics
oh and a pic of both bikes is in that link just to prove what i was saying isnt bullshit about having the second busa
how about sending me some decent pics and some more info on your car so we can compare apples with apples
Edited by Xhiler8r
  • Replies 56
fat bike i want my license bak.
i would trade my 32 straight away but no license.
other then that mate CONGRATS on the best busa i have ever seen.
GL with it and hope u dont get more tyre kickers
thanks for the comments and i doubt that the tyre kickers is gonna ease anytime soon
I thought this would be sold by now, someones going to end up with a good deal.
I am amazed it hasnt sold yet I have had a lot of tyre kicking tossers asking questions and saying that they wanted to swap and organising swap dates and then nothing they wont even answer emails or PM's or even phones
I cant work out why it is so hard for the people that appraoched me for swaps to just ring up and say dude i have changed my mind sorry ok, I am a chicken shit and a turbo Busa just scares the crap out of me, instead of acting like 10yrs school boys that havent had their balls drop yet and too gutless to contact you ( You guys on this board know who i am refering too i dont need to mention names )
anyway getting a roady in about 2 hours time for it so it will be sold with a RWC and registration to QLDers only
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
