carbon fibre
seriously, ide much rather perfer a carbon fibre one. its a fiar bit lighter, they are able to withstand alot of shock, ive seen them drop wheels form about 6foot and land on the bonnet, it jsut bounces back into place.
for me to get my bonnet repsrayed i would be looking at alteast 900 for ontop and underneath. and thats the price of a carbon bonnet. when you buy them then dont need to be painted, they come with a clear coat so its all ready to bolt on.
https://www.sau.com.au/forums/topic/20969-carbon-fibre/#findComment-441281
hhmm....your sprayer must have a mansion. I was quoted $450 top and bottom - and Carbon fibre bonnet for $1500...Green-Ghost was talking about looking good, in that case, I'd save the $1050 and go get some neons, and maybe fit a PS2 into the car ...
never understood the flashing club and show car boys.
https://www.sau.com.au/forums/topic/20969-carbon-fibre/#findComment-445140
its just like body kits, people put them on for looks, i doubt very much there are many of you that have put a body kit on ur street driven line to improve aerodynamics or lighten ur car, a carbon bonnet is next on my list. but the one with fiberglass underneath, 3 k is a bit pricey.
https://www.sau.com.au/forums/topic/20969-carbon-fibre/#findComment-446343
Guest JaSiner666(AFF66)
i'm in the process of getting one for my hr33, it is the fibreglass/carbon fibre reverse vent, i'm also after boot and wing, it is just for looks not weight saving, ..if you have the cash then do it.......BUT!, i hear the stuff is illegal, they don't have crumple zones, i need to check up on this thou.
https://www.sau.com.au/forums/topic/20969-carbon-fibre/#findComment-453098
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
