As many of you would know from last cruise I need two thing on my car
my baby needs new sets of tires hehheh :P
and more will power to stop engaging my 4WD system
so How much does it cost? what size etc...
I think I have 16" stock rim and YOKOHAMA 205 I think...
any input will be good or know anyone owns tire shop?
cheers
Joe
https://www.sau.com.au/forums/topic/2097-tire/
hey Joe u thought about putting bigger tires on the back then on the front.
So if u can get 2 good tyres put em on the front and put new ones on the back till u "wear em in" :burnout: then do it again:)
Hmm maybe this is me thinking out loud:confused: But im pretty sure u can put wider tires on stock rims. Gradenko did it:uh-huh:
https://www.sau.com.au/forums/topic/2097-tire/#findComment-38677
Boostzor, i don't think ATESSA likes having different sized tires front and rear, it wants identical widths all the way around.
I just found out today that I need new tires as well (rears). Tire place I was at (Ian Diffen Canning Vale) had 2nd hand tires to suit out rims for $35 each. Might want to try that pva, if half tread is all you need.
https://www.sau.com.au/forums/topic/2097-tire/#findComment-39931
Originally posted by Pva_Glue
so is Ian diff cannington have $30 tire or what?
Jesus Joe, that was weeks ago... they may have them still but if they don't, plenty of other tyre joints sell 2nd hand rubber. Ring around.
Don't you think you should replace them soon? If nothing, it'll save you from a yellow sticker and a $75 fine.
https://www.sau.com.au/forums/topic/2097-tire/#findComment-46086
Haha :bahaha:
Joe, those tyres you have on are waaaaaaay to bald, i swear those front tyres have no corners on them and are smooth. I saw them months ago and needed changing then, lol. Its no wonder it gets so sideways around roundabouts, in the dry. It's not worth risking it, especially when you need those tyres for braking. Unless you can find some half decent 2nd hand rubber, i say fork out for some new tyres :P
https://www.sau.com.au/forums/topic/2097-tire/#findComment-46115
insurance doesnt cover you if crash with non-australian spec tyres, its considered as unroadworthy
joe if you wonah be stingy just go out at night and take the tyres out of the tyre shops bins (yes this has been done before) but if i were you id just buy some 205s they cant be that expensive
https://www.sau.com.au/forums/topic/2097-tire/#findComment-46259
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
