Hi all,
I own an R34 NA GT sedan (got 3 kids). Great car, I love the sound as I pull out of the drive way - just as I accelerate I can feel the power kick in. Used to own a '96 Toyota Camry mind you.
Looking to put an air pod filter in, new panel filter, bigger cam gears and get a new paint job. also need to change the water pump and timing belt. atm it's gunmetal grey. Stock except for the rims. Can't wait - need to save $$$.
Looking forward to learning more and meeting some interesting characters.
Cheers,
Anna
https://www.sau.com.au/forums/topic/209766-new-owner-r34gt/
Hi!
Wow... A mum buying an R34... You don't see that very day! :thumbsup:
Nice to see you've got some tuning ambitions... I don't know what the go with NA is, but if you've got VCT (Variable Cam Timing), I'd advise you keep it, it helps with midrange power, something which is even more vital without a turbocharger... I'm doing some work to my R34 turbo manual sedan... I'm doing my darnest to keep my VCT, with tomei poncams...
https://www.sau.com.au/forums/topic/209766-new-owner-r34gt/#findComment-3708541
Howdy,
Yes and you can imagine the looks I get. Esp. from the youngens in their tricked up lancers and what not. I'm 23 and asian so that doesn't help because they think I'm some ditz in an R34 who just turned 18.
But yeah I'm easing my way into the car scene. Wasn't really into the whole business until I got one, now I just want to do all these things. but I know I need to slow down and research.
I think first thing's first, timing belt and water pump need to be changed because I've reached just over 100k in kms and have recently changed ignition coils to splitfire coils. Fiance (he owns an R33GTST) told me when you change the coils its best to change the timing belt and water pump as well. What are your thoughts on that?
I want to respray the body Burple (Blue/purple) . Still researching on how I should go about it. Any ideas?
Not sure which cam gears are actually in there so I should find that out before I do anything.
Thanks for your advice Mark, hope we can talk more =)
Cheers,
Anna
https://www.sau.com.au/forums/topic/209766-new-owner-r34gt/#findComment-3708762
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
