kuro, i think the wire that you may be talking about is "wire 53" which is the speed cut/HICAS diagnostics wire. This doesnt send the pulse to the speedo to give it a speed reading. looking at the ECU diagram it doesnt reffer to any speedo wire, just a speed cut out wire which makes think that the wire is attached to the gearbox? if its is, i wanna know how to access it from inside the cabin and what wire is the "signal"wire or (+)
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
