As it says Apex'i Power FC with hand controler in box and S15 injector package for RB25det.
I am selling this as a compleate package and i am not seperating or shiping interstate and the price is firm
and its pickup only so dont pm me asking me to seperate, negotiate price or ship interstate. because the answer
will be NO!
If there is no problem with this please read on... :D
As stated before i have a Apex'i Power FC practicly brand new in box.
only a couple of months old. the box has been opened and i have run
it in the car for about 30 mins then it was pulled out and put back into
the box until ohter modifications were done and it was ready to tune.
I also have a compleate set of 6 injectors out of a 6spd manual S15.
the injectors are in a RB25det fuel rail and are ready to bolt in.
I also cleaned the injectors, checked spray pattern and flow tested them
at work.
The spray patern is perfect even spray and the injectors flow 480cc.
(off the top of my head i think it works out about 95ml over a 10sec open flow interval)
My plans have now changed and the Power FC and injectors are now no longer needed.
Grab a good tested package for a reasonable price.
I am asking $1400 FIRM and a cash payment for the full amount is required on pickup
I am located in sydneys western suburbs.
and you can contact me via PM through SAU
or you can sms me on PH#:0433-750-636
Kind regards
Dave
Edited by MR FLWLSS
https://www.sau.com.au/forums/topic/209815-sold-please-delete/
i cant belive theres no intrest in this from anyone in sydney :)
I coulda paid you by now.. but am in qld.. oh well. i'll prob get scammed for the one on boost for $800 new. haha
ive been scamed outa stuff before and its no good thats why i like pick ups and cash exchanges
Your the one selling it though..., shipping will only be about 20 -$30
I would buy this, but I don't think I have $1400...
Plus Western suburbs are too west for me, and I am too lazy :action-smiley-069:
Would you accept a turbo to supplement the price? :) (see sig)
I'll see what I have in my bank account on Friday when I get paid...
lol how do u get scammed as a seller?
buyers risk..
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
