hi guys just finished a rebuild.. so got lots of things that need to go.. ill put pics and picz and prices soon. please comment if interested here. so i know what pics to put up 1st..
all parts are of a r34GTT 99 but would fit any r34 90 000ks gtt.
- standard fule rail and standard injectors still in it FLOWED WELL till 325 that i had b4 $550
- HKS 600cc top fed injectors x6 (BRAND NEW IN PLASTIC) ended up going with 850cc due to change of plans.. --- $750 i payed 950
- standard low mount manifold. $200
- KKR 480 turbo and intake pipe and front pipe K&N filter and custom dump pipe and FMIC piping that will all BULT ON a r34 to if u just have a FMIC this made 325hp on mine with standard injectors and just a fule pump and front mount. done about 5000ks NO SHAFT PLAY AT ALL i spent a shit loads to make this one a bolt on GRR but i got lucky it wasnt a bad one and didnt bollocks up on me :teehee: pulls realy hard when it comes in. $1300 for the lot
- Gready td06H-25G POLISHED turbo and gready dump pipe about 15000ks, and i think a ebay stainless top mount mani which ill throw in for free. the turbo alone cost me more than that. (youl LOVE this setup but u need ur own external gate) $1900
- GT35R BRAND NEW TURBO only put it on for 2 hours didnt even tune, never even spooled it once so she is as freash as a Virgin and went with a BIGGER TURBO :P $1500
- standard suspention with after market spring (not sure what they are) still in great nick i dont realy know why i chaged it. make an offer
- Gready boost controler ( bought it here from someone and ended up putting a AVCR in) $340 (sold pending payment)
- standard exohst mani and throtle body and cable. ( you can get it and polish it while ur cars still runing..)
- HKS SSQ BOV with skyline adaptor on it will fit r33 and r34 standard adaptor plate.. (no leaks) $290
- monza BOV $190 NO LEAKES sounds wiked.
- one rpm Gauge and shift light and one smoked boost gauge.
- NEW Greddy Cam Gears for rb26 $255
- NEW gready clear cam cover for rb26 $100
- standard r34 cam shafts $390 for both
- standard coil packs "they worked fine at the 325rwhp i was making b4" $350
location is PERTH "NOR", prefare local but can ship on buyers expence.
lots of other bits and peaces but ill add them when i get some time to clean the mess.
please just post here if interested and I shall get back to you, thanks.
would trade stuff for Rims as im looking for some or some slicks for the back, or yellow coned pioneers in good nick.
Edited by drmafia
https://www.sau.com.au/forums/topic/210188-r34-parts-clean-out/
sorry guys my inbox is full of msgs now and i cant reply .. which is why I asked everyone to post here i took some quick shots with my phone but ill take some proper ones soon, i dont know what the standard stuff are worth to be honest so if u have a need for it make a fair offer, the car had never missed a beat and has always been babied as you all can see its always beeing changed and played with..
by the way if anyone has some nice light rims that would go with my car and need something here let me know as im rim hunting.. ( want a 3 peace back and chrome dish and hopefully some yellow in it "might have to do that bit my self")
Greaddy polished turbo and mani "there is also a gready dump but ill take another shot with it in too"
the KKR480 and the gt35r in the boot some piping, standard planum and standard low mount manifold which the kkr mounted onto..
ill take some proper pics of it all when i organise things a lil im still working on the car to finish it up in 2 weeks hopefully.
  • 5 weeks later...
  • 1 year later...
  • 9 months later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
