Was planning on getting a remap...
get the new Fuel pump and Boost controller first then remap?
if i get new injectors, fuel rail and FPR will i need another remap?
bigger turbo another remap?
is it best to wait till i have all mods on then map? or do i only need to map some mods?
cheers
https://www.sau.com.au/forums/topic/210286-when-to-remap-ecu/
if you want to save money then get the remap at the end of al your mods, DONT PUNCH THE F*** OUT OF YOUR CAR WITH MODS THAT ARE NOT TUNED FOR THE CAR
if you want to have maximum power through all the stages of your modding, and dont mind spending a s*** load of cash, then get re mapped whenever the hell you want.
yeah good advise from the boys above, buy all your bolt-ons first then book it into someone like Shaun at Boostworks who can bolt it all on and tune at the same time.
The diiference you'll feel with the car b4 and after will blow your mind.
Speak to Shaun about what sort of bolt-ons to buy as well if you're not sure.
well said sled thats my plan of attack anyway....and i think thats the best way and the difference you will feel after a shitload of mods going on at once would be amazing...can you imaginge going from 150-180 odd rwkw to something like 280rwkw would be nice
:P
Get it tuned at each stage, or put all bolt ons at once and tune it. Anything else is asking for trouble.
I'm going to take the Stagea out to Mallala for a benchmark time, then dynoed for a before-and-after comparison.
Then I'm fitting my intercooler kit, turbo etc etc and do it all again to see/feel the changes.
if you have a safc you can do step by step tuning as you fit stuff
thats what Ive done for over 2yrs now
but Ive been hoarding my last lot of mods, ready for the remap at speed labs
going to arrange it soon.
thing is, after a remap, no point in adding extra stuff like larger turbo, 'cause the remap will be worthless
you can run a larger turbo, z32 afm, fpr, etc etc etc etc etc, on a safc, get good power and ok fuel economy.
Ive got larger injectors but wont put them in until remap time.
I was going to use a R34 GTT PowerFC but decided not to. for sale for $1200 firm. works a1
yeah that is the best feeling but can also be dangerous for someone young & inexperienced.
can you imagine going from a 13 or 14 sec car (which is pretty quick anyway) to a 10 or 11 sec car in a couple of days?! :blink:
thats what i was thinking for joel, i reckon you should get you pump and elec controller put in then get her remapped, it would be a while before you go bigger turbs, injectors. afm ect ect i think it would be better for you to go stage to stage, as even with these slight mods it will ne a dramatic change with the way the car drives
Um, that's pretty much what SLED said to do...
Thats why I said :blink:
You've been here 13 months and thats your 8th post? :laughing-smiley-014:
Edited by RubyRS4
i think ill get fuel pump then map, by my turbo injectors etc. sit em in my room until i have more cash for another remap.
krishy you will need to buy a 2nd hand RB20 ecu to get remapped and hooked up to your car. Check the SAU classified thread, should only cost $100 or so.
thx for the input guys :D
i have been told that you cannot retune/ remap a r33 ecu so how should i go about getting mine done....any cheaper way of doing it apart from a PFC
You heard wrong. It can be done. Just costs 3 times as much as a standard remap. RB20 ECU can also be used. So can Z32 I believe... not 100% on that. Ring Jeff @ The Speed Lab, or Shaun @ Boostworx and get some advice from them. They'd know better than anyone and wont just try to get you to spend cash, actually tell you what your best option would be.
what coin for the fpr bitch tits? :domokun:
$180. Brand new. FPR alone here in AUS is that price. You get nissan adaptor with it ($50). Buy it now ya poof. I gots 3 sets of wheels to pay for LOL Then again Danny I might do you super special secret squirrel deals...
Edited by R31 drift pig
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
