Guest Aj-rb20
Hi can anyone give me some advise on getting an engine that has not run for a while going again.
I was thinking to
change oil and filter then start it for 10 mins and do the same again
Should I run an engine flush thru it? or get it carbon cleaned or something?
The motor had a new turbo 14 months ago. should I pull it of and service it?
Thanks
Aj
https://www.sau.com.au/forums/topic/21049-engine-not-started-12-months/
The Fuel is the most Important thing..I have had a gtr r33 sitting in our work for atleast 6 months and The motor will build up residue that can cause internal problems...Make sure you get your Oil lines and Fuel lines Cleaned then Bled so there are no blockages...
Once the car is driving again drive it easy for about 100kms so the motor cleans out all the old shit...Then it should be Ok the Thrash it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
