hey guys/girls
i got a Beltronics Vector LR that i received of a mate for free as he said it wasn’t working last time he checked. i found a power connection for it and turned it on, and as my mate said, it comes with a error.. it starts of normal and comes up with the normal start up display but after about 5-10 seconds of being on it comes up with . " ?LO1 CAL" i asked some of my friends and one said it may be a calibration error.
Does anyone know what this error is or what " ?LO1 CAL" stands for. also does anyone know whether this problem is fixable and if so an approx. price.
Thanks any help appreciated niran
https://www.sau.com.au/forums/topic/210675-radar-detector/
hey guys/girls
I found that powering it on from cold it worked fine, if it was in the sun for too long it would start giving me that error. Lucky for me it was still within it's 3 year warranty and I took it to a supplier and repairer and they actually replaced it (and with a newer model), place was called Neltronics in Subi.
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3724498
hey guys
i rang up neltronics however the number that was on yellow pages, does not work.. If i try ringing, it just says the call could not be connected. the number i dialled was (08) 9388 9950, does anyone else know of another number for this store??
Thank’s
niran
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3725306
OK.. here's the story...
"LO CAL" (or "MARKERS" or "PLL LCK") is a fault code describing some kind of error has occured during a calibration test. BELTRONICS are keeping their software to themselves to avoid Chinese manufacturers from reverse engineering their products and whacking on the software... smart hey! :)
To repair this issue we would hopefully have a replacement board here in stock... we simply open up your faulty unit... put in the refurbished board... set up the menu and bands and away you go. The faulty board is then shipped to BELTRONICS to be refurbished and reflashed with new software.
The software repair is $95.
In WA cops use:
Multanova (not multinova!!!) which is a Ka band radar signal... low output so hard to detect
Patrol cars which use a K band radar signal... strong power so easy to detect... BUT... remember not every car is equiped and if they are, they might not be turned on
Sgt Plod himself uses a hand held laser signal... very strong, very fast, very accurate, VERY NARROW so damn hard to detect unless its fired right at your detector at which point they probably have you anyway.
That concludes todays lesson kiddies... now you can all go home, except Ossie... come here for a touching!
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3726617
$95 to repair? What about warranty ;)
Need I say more!!!
Plus the fact that a Vector LR came out around 9-10 years ago with a 1 year warranty.
Pulp, what unit do you have?
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3727163
    • Have you tried to start it with AFM unplugged? From memory with TPS closed and AFM unplugged an RB25 will start and idle (won't rev). This will tell you it's either AFM, AFM wiring, or tune. You also said Z32 ECU with Nistune?  Have you made all the necessary changes like the change of the ABS input on the pin the Z32 uses for TPS closed? Was the Z32 specifically setup for RB25 S1 or S2 from R33? There are differences between that need mods done on Z32 ECU. What's the part number on your Z32 ECU?
    • You've been so patiently waiting for your moment!  🤣 Haven't got enough time on the freeway. I did drive it up from Canberra but I have no idea how it did in this area.
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
