Hey guys im currently trying to sell my car but im getting mixed emotions on how much its worth
Need some honest opinions if i am asking too much? Let me know hwo much u think it is worth I havent seen much cheaper than this. Im getting the feeling that the market for import cars isnt too good at the moment
Im getting the front bar repaired and side skirt resprayed. Having a front end wheel allignment done 2day. Also will be servicing it in a week or so.
Check it out and let me know
http://www.skylinesaustralia.com/forums/R3...html&hl=r32
Thanks guys any opinions would be great
https://www.sau.com.au/forums/topic/210736-how-much-is-my-car-worth/
i almost bought this car from the previous owner. had stockies at the time
umm well its an r32 which seems to hold its value a bit better but its also auto and 4 door which isnt so desirable. manual/4 door is a differnt story though...
K's sound genuine aswell. i think around $9000 would be a fair price.
dont drop the price too soon/easily there's always someone willing to pay what your asking for it just be patient
good luck
Yeh thanks mate. Yeah since i bought it off that guy i have put the dish rims and a 3inch exhaust. have a cooler which i have not yet fitted but would come with. Yeh true about it been auto. I was gonna put a manual in it but decided i would sell coz its 2 expensive for my bf and I to have turbo cars lol
Yeah i guess its just a waiting game :P If my boyfirend sells his 180sx b4 i sell this he said he will buy it off me lol.
good luck
