Make: Datsun
Model: 280zx Fairlady
Year: 1979
Engine: 2.8lt Injected SOHC (L28)
Transmission: 5 Speed Manual
Color: Black
Registration: VJF-736
Rego Expiry: Expired - will register at cost.
Options: Power Windows, driving lights, Factory Alloys (full size alloy spare as well as space saver), CD/MP3 Player, Z Tech trip computer (mid 80's addition, speed/volts/fuel consumption/distance/clock/etc...) and Sports exhaust
Comments: Has some rust (under rear LHS window, under tail lights) but otherwise straight clean car. Engine purrs, no noises from gearbox or diff - has been sitting for about 8 months so will need a service. Tyres are about 85-90% tread.
Price: $2000 ono
Contact Details: Phone AH 8723 5808 ask for dave, email: [email protected] or PM
Edited by soslo_31
Had one of these classics as my first car, they're pretty well outcast along side the other more sportier Zs but still a nice car! I'm keen for another at some stage for a RB conversion, I'll keep an eye on this thread... Good luck with the sale :thumbsup:
for those of you that have saent me a pm asking about k's I am not sure about how many km's the car has done. The original instrument cluster had about 78000 on it, but had to be replaced (buggered speedo) and I have done about 5000kms since. I can't be sure how many times around it has been.
and all pm;s replyed to
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
