as said above.. your hearts gotta be in it.. if your just buyin one cos they are pretty cheap and just want the power then dont get one... but if you love the 32's then its an awesome car.. but need to spend the money on it..
but you do need to shop around...
otherwise like GeeTR said buy a 2nd hand WRX..
Edited by 02_FNE
https://www.sau.com.au/forums/topic/210980-buying-skyline/#findComment-3734343
Most 32's will be in the same stage. Things are starting to fall apart and leaking, but then again, I don't see what turbo car you could get for $10k that won't be.
Check out a few 32's for sale if you really want one. Just do a few tests on them to see if you'll have to spend heaps of money.
https://www.sau.com.au/forums/topic/210980-buying-skyline/#findComment-3739481
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
