Hey guys,
Im looking at doing some track days soon, mainly circuit stuff. The car is a R34 N/A GT-four
I want the car to handle the best it can for track and street.
So far i have
-Cusco Coilvers 10 rear, 8 front
-Nismo front and rear sway bars
-Cusco Toe arms, caster arms, rear upper arms, strut brace, tension rod (all adjustable)
-Ikeya Formula Traction arms.
-18x10 wheels.
(all suspension arms will be going in this weekend)
What else would you guys recommend?
What brakes would you guys recommend also? looking to spend around 3k for fronts
The car will be getting a RB26 later this year with some power so i need to be able to stop good.
Thanks Luke
Edited by Luke_ENR34
Hi mate l think you should add a hicas lock bar and pineapples.
Me l would get the GTR brake pakage with slotted rotors braided
brake lines should fit your budget just fine if you shop around.
But a mate of mine has a set of big 356mm 8 spot brakes from
just jap which if you go this path they work pretty dam good.
Good luck with it
GTR callipers front and rear with good pads..
Slotted and drilled disks..
Braided brake lines only if their cheap through a GB of sorts or else its not worth it.
or.. for 2K the Just Jap package mentioned above.. you will also want to up grade the rears too.. (GTR's and disks should do)
That way you have a good brake pakage and least $1500 to spend wither on your 26 or loose weight off the car.
btw. If putting in a HICAS lock bar.. its worth going through with the effort and removing the HICAS system all together.. its about 40kg weight saving too..
Edited by GTS4WD
My car comes standard with no hicas as i found out :thumbsup: got attessa instead.
Ive been offered some R33 GTR brembo's front and rear full set for under $2500. Is it possible to get them slotted?
Thanks Luke
My car comes standard with no hicas as i found out :) got attessa instead.
Thanks Luke
HICAS is the 4 wheel steering system, doesn't your car have a little computer in the back boot behind those covers...?
And then a little bar near the back wheels.
HICAS is the 4 wheel steering system, doesn't your care have a little computer in the back boot behind those covers...?
Nope, no bar. Just a Attessa unit at the back right hand side of the car and a container in the boot to fill with attessa fluid.
I can get pics if u like :)
If you go GTR brembo, dont use DBA4000 rotors as they crack under track punishment. DBA5000s seem to be ok. If it were me i'd use G4 kits tho.
You havent mentioned tyres.... if you're really serious you'll get two sets of rims - one with R spec tyres for the track, the other with street tyres for, uh, the street...
If you dont want to run two sets of rims, go for something track friendly like Falken RT-615s or Federal 595RS (not 595 aka 595SS).
The R33 GTR brembo's come with the rotars also. so gonna be using them.
Thinking maybe later down the track i will get another set of rims and use those with some semi slicks.
Cheers for the info.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
