Hey guys,
Posting this for my brother who also has a 32gtr. Has the following engine mods:
Built Motor: Forged pistons, ARP bolts, eagle rods, N1 oil/water pump, 33 crank, rebuilt head etc etc. Basically all the usual good bits
Turbos: Rebuilt R34 bb gtr turbos with N1 steel wheels
Exhaust: Upgraded Y piece with a 3" cat back. Dumps are stock
Atm boost is stock (~10-11ish psi judging by the factory gauge) whilst the motor is being worn in with only the boost restrictor removed & still retaining the OEM solenoid.
Fuel system is stock.
Looking at raising the boost shortly so my brother called a reputable tuner here in Perth. He suggested the following:
bosch 040 pump $500 installed
Greddy Profec B $550 installed/setup
Nistune $880.
+ Up the fuel pressure a little to achieve ~17psi reliably without having to go bigger injectors
Was thinking about purchasing the Nismo pump for $400 as its a straight drop in and setting up/ installing the profec B myself (done these before) to save a little $$$.
Questions are: is the volume of air produced by the 34gtr turbos greater than the stock 32's?
If we run 14-15psi without the tune would this be safe? Assuming the bigger fuel pump is in place
How much boost can these turbos produce whilst keeping in there efficiency & what would an approx power figure be?
Is it safe to up the fuel pressure a little for this application? Bigger injectors are a better choice but then + $800 for some sards which we'd rather avoid if not necessary
Thanx
Mike
https://www.sau.com.au/forums/topic/211794-built-motor-32gtr-34gtr-turbos/
N1 wheels in the front and rear? If so, 20-24psi is what most run being they arent ceramic.
Basically the same as -7 or GT-SS
Might not get there with just rail pressure as personally i wouldn't push R32 GTR injectors harder than factory pressures.
They are 15 years old and could fast become a weak link that could result in a pretty nasty death :thumbsup:
With a tune, should be a nice 300-330rwkw car if you get injectors, VERY fast streeter.
Thanx for the fast reply.
The receipt says R34 BB gtr turbos. Rebuilt with N1 steel wheels (exhaust). Previouis owner said the compressor is standard. Would N1 steel wheels fit the stock housing? Or is the housing changed. Arnt the compressor wheels steel from the factory & turbine ceramic?
Yeh should go nicely. Atm is slower than mine: stock with 14psi & cat back, but thatllm change.
thanx for the advice
270/280 or so i'd imagine direct replacement... on around 18-20psi
Thanx Nismoid. Was about to post another reply as i just found the answers i was looking for in 2 threads on stock size steel turbines vrs N1 specs from 06 & 07 with your replies. Your info was consistant :). Should have searched a little longer be4
Mike
Edited by Mike__
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
