Yeah the clutch works fine and it is needed to change gears once enabled. On the G25 the buttons located on the Shifter unit act the same as controller buttons. So if you look above the D-Pad you will see 4 buttons (not the red ones below it) and if you know you PS controller well those 4 buttons are the same for square, X, Triangle and Circle.
Nice!
So can u fan the clutch while stretching a gear for example to get the car going a little..? :P
for example if uv just completed a hair pin and ur stuck lagging in bottom of second gear can u just tap the clutch like u would in real life to get it going?? :/
what kind of seats are u guys using? where did u get them from and $$$??
cheers
I use my couch and table... Room isn't big enough for a cockpit. I did have plans on my PC somewhere for building one for the G25 but it would be easy enough to make your own.
Nice!
So can u fan the clutch while stretching a gear for example to get the car going a little..? :(
for example if uv just completed a hair pin and ur stuck lagging in bottom of second gear can u just tap the clutch like u would in real life to get it going?? :(
yes you can
cheers
using a recaro. spare seat until we got time to put it into my mates car
haha nice!
Anyone got any youtube clips of someone having some fun with the clutch?? they all seem to be no idea panzys on youtube scared to have some real fun...
And what annoys me the MOST is most clips of this game on youtube are edited gay **** background music!! why do i want to hear that?????????
The reason for the ghey background music, is the fact that GT5 has even gheyer sound effects than the gay music! LOL!
I'd RATHER hear that music than the shitty sound effects honestly.
And the reason many videos are shit, is because GT doesn't let you do, what you SHOULD be able to do in a car.
Oh and PLEASE, PLEASE, PLEASE for the love of god DON'T BUY FROM i-Tech, they are one of the biggest rip offs in the industry, you're NEARLY better off going to Harvey Norman, you can save that much money going elsewhere it's not funny, PM me for some DECENT links.
Edited by KANiVA
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
