4my son memorial cruise
posting this for a mate
meet: city west
time: sunday 1.00 pm "day cruise"
gold coin donation, go's to good cause
(hollywood hospital's palliative care unit)
Also to proove that not all import drivers are hoon's!
local newspapers should be attending for when cheques are handed to hospital.
all welcome
:P
https://www.sau.com.au/forums/topic/212455-4-my-son-cruise-30th-march/
sorry if i just crawled from under a rock here. But what is the story about "4 my son" any back ground info, why is it a memorial? I know it is a 180sx that is around perth ( i think swear i have seen it) some kinda explaination would be good.
cheers
i dont know the full story myself hey..
jst put it up for a mate
yeah theres 4my son which is adrian lee's old car..he passed away
to cancer (not sure what type sorry if i offend) last year...hence the cruise
but his little bro has 4my son2 on his 180 aswell
thats all a know lol sorry :D
I Wish i can come with you guys my car has droped a cylinder or coil packs i do not know yet it sounds like a sick Wrx. Any ways i will come down and toss a few goldies in a can for you i shell be in my mates white Peugeot 206
Change your Spark Plugs.. all of them..
Yeh i should b down to there to check it out :-)
-SeS
-SeS
yer okay i will buy a set of 6 today if super cheaps open. thanks just need to find where there are on me 34 lol i am not mechanic minded probly take me 7 hours
i will be there with my skyline sounding shit because me friend will not let me take her car.
Edited by DiNoBoNeS
was nice to see a good turnout of people =)
couldn't stay for long tho had to leave after burswood had work =(
some sweet as lookin cars tho=)
loved the silvia with the CF bonnet with me in the tunnel car sounds awesome!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
