Hi Everybody,
We are pleased to announce a new competition to be run for the month of April.
We want you to design some t-shirts, hats, aprons, whatever! This is going to be for the new SAU cafe press shop opening soon.
The top 4 designs (as chosen by the members) will win an SAU sticker and their design on a tshirt!
Your design can just be words, it doesnt matter. We have had winners in our comps before who are not designers. Everybody can enter this and have an equal shot at winning.
Rules:
  • Submissions must be in by midnight AEST April 30th 2008.
  • Your design must be able to be used on cafe press - that is, it must be an image that can be applied to the front or back of a shirt/hat/apron. It can not wrap around etc.
  • Your designs must be your own work
  • Multiple submissions are accepted, however, you can only win once. The most voted for design will win.
  • Your design's ownership will belong to SAU - this is so we can reproduce the design for more t-shirts.
EMAIL YOUR DESIGNS TO [email protected] - Submissions posted in this thread WILL NOT BE ENTERED!!!! This is to make it fair for everybody. We will post the designs in a poll on the 1st of May for voting.
Thats it. Get Designing.
Christian
https://www.sau.com.au/forums/topic/212912-sau-competition-design-some-apparel/
Some that i have made for SAUVIC... not hard to mod to be generic SAU ones :thumbsup:
OR......................
Thats right ladies and gentlemen, clothing that works just as hard as you do!!!
Clothing for everyone, from Motor sport right through to the Chapel st cruiser.....clothing that will never let you down in the most uncomfortable situations, whether it be understeer down the GOR, on the track on 2 wheels, Drifting into a wall, to being pulled over by the cops on Chapel for a full road worthy and EPA check.
These are the undies you need!!!!!
SAU VIC Brown undies
For all the time that you've shit yourself in the car, and wanted no one to know :)
  • 4 weeks later...
  • 4 weeks later...
Well, the problem is that we only had 3 entries (or maybe 4).
We're not trying to cheat you guys, I promise, just trying to work out what to do.
We'll likely add all the designs to the cafe press shop or get them made locally. Sorting this stuff out now, sorry for the lack of info.
Christian
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
  • 7 months later...
If we ever think of making a new one. This but maybe better in over-all blue- and made out of the same thick stuff as over-alls. None of that thin blow in the wind crud. The SAU.com is an embroidery, not a print (like a badge). Maybe also include an option to get members names embroided upon sale as an option. Its very simple but I think it will be the most effective.
BTW, You guys have *not* been forgotten. New merchandise will be ordered soon and the guys who entered the original competition will be given free shirts.
Christian
  • 4 weeks later...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
