last year there were only 5 or 6 ACT members and about 35 NSW... How would it work if its the same this year?
Im going for the "Fastest R32 Gtst" title again this year... But I think that Reece will be in his R32 this time and not the Starlet so there could be some stiff competition. :)
But ACT still did very well with only those few...
We go up against Vic's vs NSW with only a handful of people and we do well..
Fastest R32 ay...Good Luck!
Fire Extinguisher is definately a good thing to have anyway
  • Replies 89
I spose youre right we had a couple in the top ten last year (myself included)... Im keen as mustard this year :(
Im going for fastest R32 Gtst, not fastest R32 (although that would be nice). >_<
got another question, since a racing licence is required as well as a helmet, does that mean a fire extinguisher is needed as well?
The organisers will need to confirm, but my understanding is that as this isn't a "speed" event i.e. chicanes will be strategically placed to bring the pace down, that a fire extinguisher is probably not required for this particular event. Although a L2S is good value because you can use it elsewhere/other events i.e. Hillclimbs and AutoSports track days at Wakie, I think you can run with just the L2 at this even.
I reiterate though, confirm with the organisers.
Bugger, I would really like some good ACT based competition out there this year... Everyone knows that I was 2.5 seconds quicker than Michele and 4 seconds quicker than Reece last year :D
5 times the horsepower, Coilover suspension, Decent tyres, Decent brake Bias
4 Seconds behind in a car worth less than your turbo.......PRICELESS!!!!!!!!!!!!!!!!!!!
Fastest Outright, I'm aiming HIGH
Going for slowest GTR, As lag will play a big factor in the tight turns... :(
RWD Mode, + Clutch kick = 0% lag
But seriously just pick the right gear and you will be fine, unless they spool at like 4000+ then its a bit iffy
^lol, 4.5 to 5 i get good boost... :) on hard at 5.5 :O
Oh, ok :D
I bet you, you could have no turbo and flog the starlet with power,
So if you don't beat the starlet, you can't blame LAG for your lap times
Edited by TURISMO
Oh, ok :laugh:
No i will blame you for driving to fast...
Edited by BNR32t
ACT, List.
5. Keith Hickling (BNR32t) - Received Payment
9. Reece McIntosh (Turismo) - Received Payment
14. Michele Guyer (Michele)
15. Mark Guyer (Tuk Tuk)
16. Brendan Donnan (Donnan) - Received Payment
18. Chris Jirgens (CeJay) - Received Payment
If i missed someone please add yourself.
Edited by BNR32t
So you think doing the back track in rwd would be better?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
