Hey.
Got a problem with an R32 GTR. Picked it up from compliance and the idiot decided to jump start it the wrong way. (- to +, + to -). After a bit of smoke he realized, and then jump started it the right way.
The car now will not start on it's own with a battery. We put a working battery out of another car in and no luck. The car will crank once but not have enough power to actually rotate the engine. If we jump start it off another running car, it will start, but only after a good 10-15 seconds of cranking.
The car drives bad. Misfires under any load, and whenever there is a misfire, all the instruments die. The gauges drop to zero, the lights turn off, etc. After driving it around for a while to charge the battery, it will not turn on again after being turned off.
We also tried removing the battery while the car was running to check the alternator, and the car kept running. (Albeit badly, like above)
Anyone have any ideas what may have been screwed up? The car drove fine before the compliance people had their way with it.
Thanks,
Peter
https://www.sau.com.au/forums/topic/213002-r32-gtr-wont-start-without-jump/
lol omfg get the guy to pay for the damages...but i doubt its the ecu
btw why did the guy try jump starting it anyway? if it started fine before?
Edited by 10MinuteCar
It took him 2 months to comply it. By that stage, I guess the battery had gone flat.
if he used a jumper pack they require load in order to work, starting this backwards still provides load, imo he prob fried the ecu hence ur intruments die, ur misfire underload is ecu related because the ecu isnt able to correspond to input given by ur sensors eg. crank, temp etc etc therefore not supplying enuf fuel under load. ide prob get it swapped with a working one to test it, this is ur easiest option.
check out the earth connections on the battery terminals and on the block where the main earth is bolted on
Off the top of my head im pretty sure its on the driver side engine mount
May be loose
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
