  • Replies 41
Posted Images
Whats with R32 GTR's and ppl losing their licence's LOL (lost mine recently). I'd get an R32 GTR, Mine was $24 without all the on road shit ya gotta pay but get a decent stock one and sould be around 20. Shouldnt take long to save up abit extra? Well worth it. but yeh, like every one else has stated, get it heavily inspected.
lol naa i diddnt loose it in the GTR i bought the gtr while i was on suspended liscence so i had something to work on :D
Edited by jenkies
Aristos can be bought for that price range, with coilovers, front mounts, exhausts and 19s!! Oh and they have 2J power!!
But seriously, save the coin for a 33 GTR, dont bother with a 32 GTR they are old as now, next year they will be 20 years old!! and for a fellow 6ft4 guy you will prob have size issues!!
found this for 20g though with no goodies but Bilstein suspension i reckon my mates would be lucky to have 50-60k on the odo but i really cant remember in the last 2 years its lucky if its done 10k km's
http://www.j-spec.com.au/list/index.php?ID=10688
Finally after going on 9 months of my car sitting at the panel shop, my insurance has finally desided that it isnt worth fixing and are just gonna write it off :D so now i have to move on :( . and thats where i need help i'll have bout 17-18k to play with. i would like a r32 gtr but everyone keeps telling me they're too old, too expensive to fix, an insurance will cost a fortune, so i would like to get the opinion of some one who actually owns one.
apart from the gtr im thinkin bout either another r33 gtst, a r34 gtt, or a chaser. but would consider pretty much anything (aslong as i can fit in the drivers seat, being 6'4" causes alot of problems).
Contact Grim.
Can't recall the price, but him and his missus are selling a 32 GTR ... they dropped the price a bit too recently.
Now that all said.....anyone want to buy a GTR?? After i fix it of course....or for a better price if you want it as is...lol. no really....im serious.....
Someone broke into it and tried to steal it. Ignition lock was busted, but it wasn't stolen.
Ask Ben about the car.
:D
not interested in wrx's heard about and seen to many things gone wrong with a used wrx, news ok but out of my budget, i was told i could get a r32 gtr in really good condition landed and complied for 17k, but the more i have the better, as for the 33gtr it is a possibility, i mite be willing to increase my budget slightly if the right one come round, my boss picked up a really nice r34 4door a month ago for 16k, so they are out there just gotta be patient and keep an eye out...
ahh and now i understand why your asking a bunch of you guys you dont even know over the internet which car to buy lol
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
