Think I gotta have a look at the Stag tonight.
I'm aware the BOV outlet is plumbed back into the inlet system after the AFM, but somewhere along this path I've got a leak. I can hear it, although all the piping/rubbers are in place.
Might get the GF tonite to rev it and get it boosting so I can find the leak.
4 Qs tho:
Anyone had this problem before?
Obviously its not harming the engine?
Is there a better method for checking the leak?
How do I get the GF to clean my car while she's at it? :D
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/
  • Replies 49
Posted Images
i am sorry to say that i can answer only no to all of the questions above :D its not good to hear that you have a leak somewhere.....i guess trace all the vacumm hoses and stuff to see what is going on where.....
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3781628
dont bother with your car running cause you may find a leak if your lucky but you may not.
grab a frezzer bag from the pantry, undo the hose clamp where your intake goes onto your AFM.
remove the afm and put the bag over the end of it and then reinstall as normal.
now remove the vacum line to your FPR or similar and stick compressed air in there. this will pressurise the whole intake system and alow you to pin point any leaks from the intake manifold right up to the afm.
leave the bag double thickness will hold about 1.5 bar.
evryone should do this now and then as you will find even the smallest of leaks.
cheers
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3781832
you havent just whacked on a POD by any chance have you?
you may have a leak in your cooler pipes, usually around the hose clamp join bits...?
Yeah, recently fitted a HKS pod. So I must have a loose clamp weaker thant he BOV spring rate when i shut off the throttle?
It actually sounds like the BOV exiting the atmosphere even so faintly.
I got distracted fitting 18" mags tonite. I'll check the clamps first thing before work tomorrow.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783055
Could be your BOV, happened to me once. It got stuck slightly open...
Coincidental that I hear it now that I fitted a pod filter!
Actually, first time I've ran a pod filter on a turboed car, so I wouldn't know.
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783072
In that case, are you sure your not just hearing the turbo spool up?
Under what conditions can you hear the noise? If it's under acceleration i would say that is the case, the turbos just spooling like it should.
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783174
Yeah those HKS pods are loud. My car sounds like it has a BOV but it's just got the stock bypass with an HKS pod.
The Mrs got pulled over a while back because the copper "heard the BOV go off". He had a look under the bonnet and conceeded that all was ok.
https://www.sau.com.au/forums/topic/214168-pssssshhhhtt/#findComment-3783916
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
