  • Replies 56
Great to see all you regulars again and also meet the noobs last night!
I wasn't kidding about the cinnamon... :P
My drive home was interesting....
Had this gay riced up Lancer, with chrome bling wheels, and a huge monster tacho where the shift light must've been set to about 3 grand, and the number plate was 050EVO trying to race me on the M1... (Pffft, EVO my ass, it was a wannabe). With a carload of absolute tossers inside. I told him to go get a real evo and until then (i pointed to an excel) race that... I wasn't even going to bother wasting any time and effort in even dropping it down a gear to give him a run.
Nadeem and i could not stop shaking our heads and laughing at the morons...
I will try to organise a bowling night for 2 weeks time. :)
^^lool
sounds like there were a lot of tossers out last night,
when the rest of us went for our cruise we ended up down by the river at southbank in a nice quiet seeming area with all the lines lined up, and a short while after we got there some fools in a pajero pulled up right in front of us and tried to pull a burnout, a short while later they came back in a lil civic decided it was time to start speeding up and down the road several times, the last time he stopped infront of us and asked if we liked his burnout in the pajero... :P
^^lool
Was good to meet you guys last night, nice rides guys. NSR034 = sex! That same pajero tried to race me aswell. We stopped, idiot bounced off rev limiter then dumped clutch...nice cherp cockheads..haha. Looks like they was doing the rounds. Anyways, sorry for leaving early guys, missus wasn't feeling the best...haha. Oh well, always next time.
Edited by hojak
just spotted that pos around my area tonite.. waahahahahah more like "050 cannot afford a real EVO" :down:
Should kidnap Will's camera next time.. :P
:down: why would anyone wants my 7year old camera? heh
most of the time the pics i take at riverside night time don't turn out that great anyway. some bright lit carpark is more ideal :D
  • 3 weeks later...
awesome cars guys would love to come up for a meet n cruise one night. my r33 not as pimped :cool: as some of those weapon looking hot machines :) though, laughed pretty hard about mr pajero n his burnout run!!! lololol :P;):P:P;):laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
