Hey guys n girls,
I have ANOTHER question about a r32 rb25 conversion.
I have been reading around a lot on this and finally finished the conversion myself which was quite rewarding.... until i tried starting it.
For some reason it wont start nor even think about starting.
There is def fuel getting through as it STINKS of fuel and i pulled the hose off to check and its pumping fine.
I'm pretty certain its not getting an spark, i dont have a timing light to test it with so i just pulled the plug out and turned it over just hanging the spark plug in the coil, and no spark.
I've been readin through the workshop manual and tested the harness and coilpacks. The test in the manual for the igniter was a little confusing but im pretty sure its ok.
Im starting to lean towards something ive done wrong wiring up the RB25 (im using RB25 loom as well) but everything seems to be working fine i.e. fuel pump, eccs and ignition relay.
Any help is appreciated.
Ryan
not 100% sure and i dont want to waste your time either, but when you say not starting do you mean, no cranking, no compression, is the engine turning over?
you say you are using rb25 engine and loom, what about the computer?
double checked all electrical connections? and not by looking but by feeling them?
is the engine used in the conversion new/secondhand/rebuilt? condition of engine, block and head?
hope this gives you some kind of idea, or even helps you.
cheers.
thanks for the reply.
the motor cranks fine. i tested most of the sensors and they all checked out ok.
the motor itself has gone rings in cylinder 2, dodgey f**k i bought it off sold it to me as working motor :S i have another block i am building but want to get this ironed out and started so when the bottom end is ready it can just be swapped over.
rip off the CAS and spin it by hand while testing the spark plug for spark (holding it near an earth), if it doesnt spark then look into replacing the CAS. try swap with someone who you know has a working one.
I know you've said you've tested the relay, but have you checked that there's power at the coil when the ignition is on?
The spark plug needs to be earthed to spark, so if the thread isn't resting on something that is earthed it won't do anything.
Awesome!! She's running. I found a plug i hadn't connected (the one that kind of bridges across the ignitor.....kinda :S)
Anyway, after a week of fkn around, thats all it was. How dumb could you be :8...... at least i know EVERY sensor and harness in my car is ok LOL!!!
Thanks heaps for ya help guys!!
Ryan
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
