Item:Seinfeld Complete 9 seasons DVD R1
Age:Brand New
Condition: Sealed
Price: 260
Contact: 0432182133
Comments: Features:
Complete 9 seasons 32 DVDs in a specially bound boxset. Comes with additonal bonus DVD not found in original boxet and
The Official Coffee Table Book: A 226-page bound anthology filled with photos, quotes and trivia from every episode.
Bonus disc featuring the exciting reunion of the entire cast plus Larry David on the ninth anniversary of the series finale.
Documentaries for All Nine Seasons
  • 4 months later...
  • 3 weeks later...
Sold..thanks for the interest everyone
260 is a reasonable price for a NTSC set ...considering someone just sold a PAL set for 390 AUD...
get them while they are still available....
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
