Well guys, after about 6months of not doing this, I finally got off my arse and did it, and it works!!
Here is the link to the original thread where we discussed options and there are a few more links in there to some usefull sources.
Thanks to a few people for helping with wiring diagrams and what not.
First thing I did was purchase a digital unit and sub loom, then if you are familiar with the conversion in S13 all you have to do is unplug the analogue subloom and replace it with the digital subloom. But since digital control was not an option in the A31/C33 there is no subloom to unplug, it's hardwired into the body loom. So I did a bit of experimenting.
I bought an analogue control unit and subloom from an S13 and plugged the S13 analogue unit into the ceffy and it worked straight away (easy replacement if your cefiro analogue unit stuffs up). So I came to the conclusion that the A31 wiring is identical to the S13 wiring when the analogue subloom is used.
So the next logical step was to repin the analogue loom using the S13 guide, but if you have ever removed your control unit, you will notice that there is next to no slack in the loom and there is no space to get your hands in there unless you remove the dashboard. Not keen.
So I made a new loom (I'll call it a hybrid loom because I can't think of anything else...shutup). It connects to the 3 plugs from the analogue loom and has 2 plugs on the end to connect to a digital unit.
There is only 1 problem now.. I couldn't find any plugs that would fit in the digital unit so I had to butcher a subloom to use the 2 black plugs, and I couldn't find any sockets that would suit the original plugs, so I soldered some PCB header pins onto a PCB experimenters board.
This is how it ended up looking
In the first picture you can see the 2 black plugs from the analogue loom plug onto those pins, and the white plug fits in that white socket.
In the 2nd picture you can see my awesome soldering skills and the two plugs that fit into the digital unit.
Functionally it is completely fine, and the board doesn't need to be that big I just haven't been bothered cutting it down, but it looks like dogs balls and the board wouldn't need to be there if I had a proper socket thing.
If you want to make your own conversion loom I can supply pinnout details.
Thanks, Luke
Edited by daisu
https://www.sau.com.au/forums/topic/214371-a31-digital-climate-control/
nice, i was thinking of doing this myself :D , sounds difficult the way you explain it though :D , i have spare all the wiring for cefiro heater controls though, wouldnt it be easier to just change the plug on the back of the digital heater control thingy?
Basically, there is no sub loom in a cefiro. But the wiring in the cefiro is equivalent of having an S13 with analog subloom plugged in.
All it does is rearrange the wiring (exactly the same as repinning the plugs), but is alot easier to install compared to rearranging 32+wires.
  • 11 months later...
Guys, I found a japanese site with wiring diagrams for the digital climate control loom. This loom plugs into the cefiro loom and adapts it to suit the digital unit.
Prototype #2, it's no where near as good looking as the jap one, but it'll do for the moment. Planning to redo it this weekend.
And it works!!
I take it your car came with the standard manual controls, and the analogue climate control you refer to is the one that looks basically the same only with the addition of an Auto button and the hot/cold slider is replaced with one marked 20/25/30, ie this one
If that's the case, am I right in saying it's simply a case of removing that analogue unit, chopping the plugs off and soldering on the plugs from the digital unit? I don't need to follow this guide that has me installing sun sensors and temperature sensors and so on?
Any chance you could draw up a wiring diagram?
Edited by Lum
Yes and no Lum,
there are 3 control units for the aircon in nissans.
Regular aircon (only option available in USDM 240sx, and some JDM S13) this is the one that has COLD-HOT written on it and no auto functions.
Analogue climate control (available in JDM S13, this is the only option available in laurels and cefiros) marked 20/25/30 and has auto fuctions like pictured above in your link.
Digital climate control, pretty self explanatory (different models available through silvia/skylines)
That guide (installing sun sensors etc) is for USDM 240sx models (and JDM models that didn't have climate control). You don't need to follow that as your cefiro already has the sunload and temp sensors.
The difference between the analogue and digital units is the wiring order. All of the wires are there, but they are arranged differently.
The analogue unit has 2 black plugs and a white plug, where the digital unit only has 2 black plugs.
You don't need to chop the plugs off as they are the same shape, they just need the wires to be rearranged, but that is pretty difficult to do in the cefiro.
So the easiest option is to make up a loom that rearranges the wires to suit the digital unit.
S13's have it easier, as that part of the loom that needs to be rearranged can be removed and replaced with one that suits the digital units.
http://www.a31cefiro.com/ryuuyou/air_con.htm
It's a japanese site, so you'll have to run it through a jap translator.
In the picture above, the large black connector on the left needs to be removed from a climate control unit (either that or you can press pins into the connectors on your cefiro loom)
The 2 black connectors on the right hand side can be sourced from an S13 climate control loom.
Or, if you want, I can source the parts and wire up the loom for you.
Edited by daisu
  • Thanks 1
If that includes the climate control unit I may well be interested :D I have no idea where I'd get one here in the UK.
I see where I'm getting confused now though. The UK S13 (sold as a 200SX) came with the hot/cold slider the same as the US 240SX and since A31 info is very thin on the ground I've been doing most of my research based on the S13 and R32 which are more common over here.
Yeah, even here it is hard to find good information for the cefiro. Alot of the S13 and R32 information translates over to the cefiro/laurel but it's all the little things that are slightly different where the information lacks.
Digital units are pretty easy to get around these parts, last time I checked they set you back about $100 or so.
That's a little less than a tank of fuel for the Ceffy, at UK prices :blink:
As soon as I mentioned this, my GF asked if she could have one for her S13 (they are hard to get over here). She'll wire that up herself though if the subloom comes with it as it's well documented for the S13 and she's a lot better with a soldering iron than me.
I suspect you'll want some cash for the work too :D
Yeah, making the loom involves a few hours work sourcing and stripping the parts, but it's not really that difficult. I mentioned on another forum I'd knock them up for $100 + parts.
Does your girlfriend's S13 have the hot/cold or the 20-25-30 type?
Yes and no Lum,
Hi Daisu,
I have also tried making a harness for the s13 digital climate control and installed in my a31. Funny thing the Fan Blower dosent operate and same goes with the tempreture settings. The On/off button fan/auto/ac and the blower positioning button does operate correctly. Did you have any similar propblem as mine? Before my climate controller is the regular type that you mentioned that uses a driffent type of looms(two white connectors) but there is also the black connector loom in the dash which is 20pin and 16pin which i plug in with my new rewired loom and s13 digital climate controller. I tried using the analog controller before (which have auto func. and 20/25/30 temp mark) that i borrowed from a friend a31 and connect with the plug connector in my dash but it did not function at all. Do you have any ideas what might caused this problems? i suspected that my a/c system dosent have those sensors that the a31 with anolog controller have.
hansmaniac -
As far as I know, all A31 and C33 had analogue climate control, which means they will all have the required sensors.
If yours looks like the one in the top of this picture then you should have all the sensors.
I did not have any problems with the fan or temperature settings, they worked straight away.
If your fan blower and temperature settings don't work, you may have a faulty digital unit, or you may have incorrect wiring.
Plugging the digital unit into the A31 without using a rewired loom can result in permanent electrical damage to the digital control unit.
Double check your rewired loom against the wiring table here http://www.a31cefiro.com/ryuuyou/air_con.htm
Where are you located?
She has just the hot/cold slider so will need the sensors and related parts too. She is however perfectly capable of wiring up everything herself (she's just a lot less likely to get around to it if it's for my car than for her own :() this is what she says she needs:
The unit itself
harness
mode door/air-mix motor
ambient temperature sensor
sunload sensor
internal sensor
this weird tube thing that I think is called an aspirator, it's to separate the internal sensor so it gives accurate readings
blower motor controller/resistor pack
apparently there might also be a relay needed?
I believe I just need the unit itself and the modified loom, and installation is basically pull the surround off, unbolt the unit, plug in the new one with this adaptor loom and put it all back together again?
Oh and postage to the UK :(
Daisu,
Its confirm, my climate controller is the regular type and its not the same as the one you posted above pic. It dosent have that auto functions. I even open up my blower speed sensor and its the the one with holes like USDM type.... Dammit :blink::blink::blink:
Looks like i need to find a complete set of sensors and harness to use a Digital controller. Anyway im from Malaysia. :)
Lum, I'll have a look for the parts over the weekend and give you a more accurate idea of the cost.
Hansmaniac, I didn't realise that the malaysian models were supplied without climate control. Putting in climate control will involve doing the same things as the USDM S13,
  • 4 months later...
hello, i'm a cefiro new user, now i have a problem for my cefiro a31...the air cond controller is burm ... :D
can u tell me about this is fix for what car?? and how about the cefiro a31 wiring and this digital climate control loom wiring ??
can u tell me about the wiring diagram?? thank you
And it works!!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
