NISSAN
[ HR31 GTSX COUPE
[ 150kms
[ MANUAL with H/D clutch
[ BLACK
[ Canberra
[ $5000.00 AS IS
Contact: Jeremy 0408605725
Modifications:Stock aprt from 16in alloys
http://i15.photobucket.com/albums/a373/pol...rm/Image014.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image013.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image012.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image011.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image010.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image009.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image008.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image007.jpg
http://i15.photobucket.com/albums/a373/pol...rm/Image006.jpg
Well my planned street sleeper is up for sale. It is in Great condition for a 18 year old car. It has a ECCS redtop RB20DET that runs well and the turbo spools fine as well. Obviously you can see it is black in colour and manual. This is a great example of an unmolested HR31. My plans were to put in a RB25/30 but I have received a job back up in QLD so I have to sell.
Transport at buyers cost although I am happy to help organising it
Edited by polishstorm
NISSAN
[ HR31 GTSX COUPE
[ 150kms
[ BLACK
[ Canberra
[ $5000.00 AS IS
Hey, how is the paint on your coupe, and is it registed.
Cheers
My brother (HR31_RB20DET - i think his username is) was selling his R31 Coupe but decided to keep it. Not too sure what he's doing with it these days, but you can try pm'ing him.
It would have to be the tidiest coupe i've ever seen...
Oh yeah, it's the coupe in my sig pic below
V
Edited by Miss Niz
paint is slightly fading on the passenger C pillar and a small patch on the bonnet but other than that all good... it is unreg and requires a new AFm as the one on it atm is from an RB30 non turbo which didnt bother me as I was going to put a RB25/30 in it. Will need to be replaced to pass RWC, other than that before i left for QLD, i gave the engine a full service and replaced any globes, bulbs, fuses, broken bits that needed it... In all honesty it is a really great car and if I could keep it I would...
Hey
Would you consider driving to qld
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
