Awww...that's the whole point of an external wastegate isn't it? What's the use if it's not going to dump straight out to atmosphere? :) I used to do that. Great sound when it opens at full boost!!! To me, an external wastegate is like a BOV. Although they do have functionality (reduces lag/better boost control), everyone knows that the real reason is for the sound. Be that a whoosh or a bark. A whoosh and a bark is even better :)
Let me know how the car sounds when the turbo is spooling. My previous turbo made a much louder noise than my standard one at present. It was a kinda high pitched noise that got louder.
You should get no probs from the cops unless you zoom past them at full boost, cos that's the only time you will ever hear the wastegate. Just be careful, that's all.
Hope the results are good!!!
  • Replies 108
Hmm...it just occured to me, looking at your picture of your turbo and wastegate...does that mean that you have cut a hole into the exhaust housing of the turbo? I believe that a wastegate has two outlets. One usually bolts onto the manifold, where the exhaust gases enter the wastegate...and then the other outlet is for the wastegate piping to flow out to excesss exhaust. Am I right in assuming that you have cut a hole in the exhaust housing? If so, how was this done?
I can see what you're saying, but no matter how well you do it it will never be as smooth as it was originally. And seeing that exhaust gases are going to flow through this real fast, it will cause some form of turbulance problems. Would even cause more back pressure than normal and wouldn't that disturpt the flow of the exhaust gas and affect the spinning of the turbine wheel and the whole turbo as a result?
amu: I think the 20G could produce more than 250kW@wheels. Probably more closer to 300kW@wheels? You said boost kicks in at 4500rpm and this is not laggy??? Or did you mean full boost (1bar) at 4500rpm?
that is full boost.... no way you can achieve 300kw on a 20g ....the 25g yes if all other things are done with it as well... between gear shifts you a still on full boost...that is the most important aspect dont you think.... everyday driving is below that... so there is an advantage there in itself
By fitting the external wastegate off the dump you can have vastly varying pressures on the wastegate and it makes the boost control more difficult. The setups I've seen done with the wastegate on the exhaust housing have all worked well, much to my sursprise aswell.
Oops! Sorry, I forgot that there was a larger one - the 25g. I think 1bar at 4500rpm is still a little laggy for street use...but then I guess it's all to personal preference. I used to have a GT3037S on my 2L and that wouldn't make any boost until 3500rpm. So 1bar probably around 4500rpm...and I thought that was a little too laggy for street.
amu: In terms of driveability, I am strictly talking about *when* the turbo starts making boost...not really considering whether or not the car is on/off boost between gear changes. And to me, my personal opinion is that a car making 1bar at 4500rpm is a little laggy for street. Just my opinion, but other people may think that's fine for the street.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
