Not sure on costs but Mobile Injector Service can do highflowing. I reccomend spending the money and buying bigger injectors tho.
What are some reasons to upgrade to bigger injectors apart from just having a newer item in there?
when your stock injectors cant flow enough fuel to your engine from either turbo increase or just boost pressure you need more fuel to equal the amount of air going in on a ratio.I woulnd tget hi flow ones my old man has had bad expericence with them.I just buy new ones and so be it plus there nto that expensive now, you can get 555cc nismo ones for aound 750 to 850 a set
when your stock injectors cant flow enough fuel to your engine from either turbo increase or just boost pressure you need more fuel to equal the amount of air going in on a ratio...
Yeah i knew that bit :P
...I woulnd tget hi flow ones my old man has had bad expericence with them...
What kind of bad experience? what happened?
stock rb25det injectors can be highflowed to approx 650cc with out losing their spray pattern once u go bigger than that ur pattern starts going all over the shop. Mobile Injector Services do these and i think they're roughly $400 and the injectors are pretty much brand new.
Yeah i knew that bit :laugh:
Well basically the guy who did these ones,( dont want to name anyone except he is from towommba area) didnt do a very good job of them plus its a bit ruthless to do them.The spray pattern is crap,like a turning on a garden house and one of the pintels in the number 4 injector was broken from his bad doing and caused number 4 piston to basically crack the length of it in two.All the fuel was washing oil off the bore,hence causing damage.Spray pattern is important.IM not sure on Rb25 injectors but these were on SR20det ones.
Highflowed R34 ones from the US....good option www.deatschwerks.com
they are awesome i had a set of them, they were flow tested a 600cc they were all with in 2cc of each other and gave me mo problems what so ever
I just had a look on the site and they look very professional. Are they new OEM injectors that they high flow, pressure test, etc, etc and resell? Is that how it works?
when i got my injectors cleaned i talked to the injector guy about highflows and he said he wouldn't ever touch them, he said he's seen some good ones but on the most part they we all crap different flow rates etc. Your motor your risk.
thats why when you get them you flow test them :laugh: like i said mine were all within 2cc, if you test them you cant go wrong
Hey hey,
I'm just looking for some names and numbers of people that highflow std R34 rb25 injectors in Brissie. What are some costs and options???
thanks guys,
Steve
why hi-flow std injectors.
you can buy some aftermarket injector for a bit more money than hi-flow std injectors.
much better way to do and brand new too
cheers
thats why when you get them you flow test them :D like i said mine were all within 2cc, if you test them you cant go wrong
Yep, they even have so many cores in stock, they flow test and match a group of 6 so the tolerance between them is very close. I've heard nothing but praise for Deatschwerks, my ones have been running great for a long time now.
They highflow the pintle exactly the same way a manufacturer would, using micron accurate drills an CNC.
yeah i nearly got a set of deathworks highflows as well but read more than a couple of bad reports of injectors failing, locking up on the dyno and sorts. But I suppose bad reports are everywhere for everything
Edited by SevenAngryPenguins
cheers
because they are cheaper and made by the same process and are effectively new
dont tell any one else that though...cause when you mention anything besides nismo when it comes to injectors they are apparently shit
I just heard they have arrived at my house... why do work days always go for so long?
I grabbed the 600cc variation of them. they are so cheap for brand new, flow tested & matched, 600cc injectors that are a drop in straight fitment... That has to be as good or better than any aftermarket brand injector, right???
And they only cost $550!
:D
Don't forget to send your ones back for cash-back!......another $90in your pocket
do they take stock ones off of any one? Or only current customers? i have like 3 sets of RB 25 ones and 2 sets of SR20 ones!
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
