I have an rb25det series 1. finished hooking up the safc2 and all is working fine.
i have one query about the knock sensors though.
there are 2 knock sensor wires on the ecu one for cyl 1-3 and one for 5-6?? is this right?
to my knowledge there is only 1 knock sensor wire on the safc, do i need to tap into both of these wires? or is there a second knock wire from the safc2?
i have the knock sensor wire from safc tapped into one of the ecu knock sensors atm, but do not get any knock readings on the safc.
i assumed there would be a small amount of knock or is it because ive hooked it up wrong.
can someone please help me out with this and clear it up??
Thankyou
https://www.sau.com.au/forums/topic/215240-safc-2-knock-sensor/
APEXI DOCUMENTATION
Includes: Installation Manuals, Wiring Manuals, Technical FAQs
http://www.apexi-usa.com/support_main.asp
thanks zennon i have that printed out at home, but found it pretty much all over the shop and confusing. ill try and have a read through it again.
but from what i can see there is 1 wire from the safc for knock and it needs to be tapped into both knock wires on the ecu.
yeah as a whole its fairly easy, was just this knock sensor thing im a little unsure of.
just make sure all your connections are sweet. the splitters i used werent the best for the job and made a dodgy connection. caused me a bit of trouble.
nah the safc doesn't have two knock wires, just one. you need to get a multimeter and probe into both of the knock sensor wires at the ecu when the car is running. the one that has the higher voltage is the one you splice into.
2nd one in the thread - you're on a roll! :banana:
haha i didnt even notice the other one. slow day at work today... my brains not working
awesome thanks qwk32 :) i'll check that out.
should an untuned rb25det be getting a small amount of knock? it shouldnt always be at zero should it? i may have read that wrong somewhere though
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
