SHELL $5k Engine package $2800
Hey guys.. this car has been my project .. been chipping away at it for almost a year now. Basically there isnt anything on the whole car that hasnt been removed.. checked or replaced.
CAR IS NOW COMPLETE
Car is located near glenelg in SOUTH AUSTRALIA
I bought it as a rolling shell... and then bought a half cut from jap import spares.
Engine had almost perfect compression across all cylinders.. tick under 100 000 km but in great nick
Turbo has no shaft play
Gear box is very tight
Fresh respray.. gun metal grey all over with black roof and bonnet
All new oils and lubes etc
Silvia front
S14 seats
HUD
New rear suspension or rear coilovers
3inch exhaust
Comes with .. vertex rear bar, aftermarket sideskirts, vtx/bn front bar extra on top of stock kit as well as almost another half cut worth of accessories.. brake lines abs controller brake boosters cross members etc.
Basically i need this gone pretty soon..
Price: $9500 firm with rego etc.. as this is already less than what i have spent on it! or 8.8k if you take it away as is and get rego yourself
Will take $7999 as is this week only
Inspections welcome before pics come up. Grab yourself a reasonably stock unmolested sil80.. great for street or track
Luke
0414391972
Please note front just has to be bolted together and simple wiring. Also paint is fresh off the gun and needs light cut and polish
Car Is now on ebay.. updated pics are on there!
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E:IT&ih=019
https://www.sau.com.au/forums/topic/215369-nissan-1091-sil80/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
