well not really. Individual race results often show "r" or "R" but they don't always seem to show the quickest times I know of around there. eg in IP at wakefield the other week Dave had R against his results but it was only a 1.07 and I'm pretty sure WW's record was a 1.069. Can't see a consolidated list on there anywhere
don't know if there is such a list of lap records. but here's a link to the IPRA Lap Record thread.
http://www.techmasters.com.au/forum/viewto...p?f=3&t=271
Wayne's old record at Wakefield Pk was 1:06.1. bit surprising it didn't fall after the resurfacing. all the talk has been that the track is seconds faster now.
Edited by hrd-hr30
hey duncan
wakefield just got slower and slower as the track kept getting oiled up every race.
the IPRA times said ® because they didn't have a official lap record for a combined grid race (over 2l & under 2l in same race) we have been under WW record twice last year only in qualifying not a race so dosnt count. we had boost issues so didnt run on sunday. we intend to pull the restrictors out and give it a run in sports sedans at eastern creek on 24 may. woo hoo :D
lofty
yeah should be great, especially if you guys are going to go all out in SS not just pul lthe restrictors out :) hopefully I'll see you out there.
But I guess the answer is....there is no single location for lap records in Aus. I'm really surprised noone's ever bothered
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
