Up for sale is an R33 Skyline RB25DET engine and original 5 speed gearbox. The whole lot is pretty much complete except the engine is missing the plastic fan, plastic cover over the sparkplugs and intercooler, the gearbox no clutch (removed).
I'd prefer to sell it as one instead of splitting it up. The engine has done about 105,000 km's, I assume the gearbox has done the same. I bought it off Ebay about 18 months ago and it has just sat undercover since , apart from turning it over by hand every 6 months. Compression is good at around 160 PSI per piston, everything else on the engine looks standard.
Included is the hydraulic master and slave (for clutch), engine computer, loom, all engine sensors, aircon compressor, alternator, power steering pump, turbo, exhaust manifold, inlet manifold, gearstick with rubber boot. Overall the engine and gearbox are in good condition, and I'm confident you'll have no trouble with it. I'll try and get some photo's later in the week.
$2800 the lot.
Any questions, feel free to ask.
ph 0418 784 062
email [email protected]
Edited by mattdieselgem
https://www.sau.com.au/forums/topic/215670-rb25det-r33-engine-and-5-speed-box/
Why do you sell it now?
I bought it before I went back to uni, while I still had access to a garage...but now I don't. I won't be able to install it for a few more years untill I finish my studies. I went a bit overboard buying cars and bits and pieces over the last few years, now a lot of it is just laying around taking up space, like my Holden Kingswood Wagons, they're next to go, thats what i planned on using the engine/gearbox for. Anyone interested in a 1971 HG kingswood wagon? I've got two, good condition.
I know you're not wanting to part it out, but would you consider selling without the gearbox? I'm considering doing an RB25DE => RB25DE+t conversion and so really don't need the gearbox at all :down: Actually, there's quite a lot on there I don't need, but 'd rather have the option of just doing a full engine-swap (replacing any missing bits of the new engine with ones from mine).
Yes, I'd if you just want the engine, I'll sell that, havn't worked out a price for engines alone, did you need the computer as well?
yeah I would.
I'll separate the engine and gearbox if someone wants one bit, $1350 for gearbox, $1600 for engine, $2800 the lot, located Sydney. I can take it to a transport depot if you want to it trucked to your state. I can get the engine/gearbox trucked to Melbourne for about $150 through a contact.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
