The valves will usually leak off anyway over a few hour period, and the way i figured it was with the valve there it actually restricts the flow from the pump so i completely drilled mine out, just when starting the car you have to let the pump prime to fill back up the lines
The non return valves need to be there in case one pump shuts down. If it does then the other will pump straight back to the tank instead of the fuel rail and you could have a wrecked engine on your hands so you have the non-return valves to make sure the fuel only goes to the engine.
The same told me my engineer! But if we have two 044 and one blow and the car run with one 044 it will blow the engine sure!!
If we have one fuel pump like stock cars if it blow, simple the engine stop to work...
What is your opinion?
Also GTRgeoff what do you have to said for the green 33 post?
It's just Geoff mate. We aren't formal here.
You have to be running a fair amount of power for a single 044 to be running at the limit. The reason for running 2 pumps after a swirl pot fed by a lift pump is to protect your investment in an expensive engine. If you lift your power requirements beyond that of a single pump (in which case there is an argument to run separate fuel lines from each pump) then you must get new pumps that will deliver the power you require.
As for drilling out the non-return valves, they are a restriction above a certain flow rate, but should not cause a problem at the flow rates expected from an 044. If you need more flow, get a larger valve. And yes they will often allow pressure loss in a standing fuel system but every fuel system has that in common. The reason for their existence is to stop the fuel finding the easiest route out, and that will be a pump that isn't running and pressure loss in an engine being pushed hard is almost a guarantee for a meltdown. Sure it may be a little more expensive to do it properly, and not as ghetto or drift cool as drilling them out for extra flow that isn't needed anyway, but it is definitely cheaper than lunching a motor.
I have two 044 with surge tank and one walbro intank. The return from surge tank to fuel tank will have a stock fuel pressure regulator without any vacum so 2.5bar fuel pressure!!!
Geoff can a T04Z runs with one 044? All people here said me no in a topic! I need two! So if one stop work and the other continue to work?? What will be the result? A blow engine!!! Right?
If we have two and one stop work without non-return valves the fuel of the working pump will not go in the engine so we will avoid the lean running.
But we will have a little fuel that will injected in the engine... because the surge tank have 2.5bar fuel pressure..
So I will save my engine with this method? Or I will blow it too?
If you have spent enough money on your engine to truly need 2 x 044's then you should spend the little bit extra and buy a fuel pressure guage. If you have a Power FC, then any leaning out will cause knock and the knock warning light will flash. If you ignore the low fuel pressure and/or the knock warning then nothing will save you.
If you don't have the one way valves, some of the fuel will still go to the engine, just less than what would flow if one pump failed and you had non return valves.
Cheers
Gary
Cheers
Gary
I certainly wouldnt be running 40 psi fuel pressure in the surge tank, why not just plumb it up like everyone else does, it works fine?
Sidneykid so there is no difference in reliability either with non-return valves or without ?
Either with or not the result is a blow engine ? :rofl:
I have egt and wideband gauges with warning so I don't think that I need a fuel pressure gauge.
But think also.... if we have non-return valves and one pump don't work we will not understand it! Right?
So more dangerous!!
Maybe when the one pump stop to work to survive my engine... but if the car still works with one pump I will detonate it many times!!
But if you think that with 2.5 fpr at surge tank the one pump will feed the engine properly at low demand for fuel so I will still don't understand the non-work pump.. so if I don't put non-return valves better to don't use fpr to stop the fuel feed totally.
Adriano I like the idea of fuel pressure regulator at the surge because I will be sure that the surge tank is absolutely fuel.
Also if I choose to don't have non-return valves the lines will be empty so long try to start the engine.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
