Hi all,
I've recently aquired a Legnum which came from Japan with a Pioneer Carrozzeria AVX-P55 screen. I have tried contacting Pioneer Aust, Japan and US with no helpful responses from anyone. I am trying to determine what the input is to the screen, whether it is AV, RGB etc?!
My intention is to purchase a Pioneer DVH P5950 head unit (or similar) which will play DVD's with an AV output inputting to the Screen. I haven't been able to get the screen out yet, but have these photos from a Japanese Auction showing the connections - so can someone please tell me, is the yellow plug AV (compatable with new HU) or is it RGB and im going to have to buy a format converter?
Cheers
Lee
https://www.sau.com.au/forums/topic/216024-question-on-dvdscreen-connections/
I think the RGB stuff you're talking about is component cables
*bling*
What you have there, is the standard AV style... Video, left and right audio, better known as RCA
*bling*
probably a 50Hz screen too... which means nothing to you :D
so you're answer is, RCA! It will be one (probably) 50Hz Video cable... so umm yeah, no converter necessary...
I figure 50Hz would be the refresh rate of the screen, so if it is indeed RCA, I should be able to hook up my home DVD player in the shed to ensure the input is correct yes? As long as DVD player has NTSC selectable output?
I just dont want to pay $400+ for a head unit that doesn't play anything to my screen
Cheers for the help Dr :D
yeah it should be fine... if you put a 60Hz image through it will come out black and white though ;)
However, why NTSC? If the legnum was imported from Asia, it will be PAL...
Either that or I am confused :D
Good luck! :( Lemme know if you need any more help!
Well I got the dash facia off on the weekend, and sure enough NTSC output on my Digi Camera output to the screen beautifly!!
Now I need a new head unit so looking at these options: Im just looking for something faily basic to make use of the screen I have - No intentions of subs/amps/car theatre type setups.
JVC KD-DV7305 Highlights
• Power Output: 50W x 4 Max.
• MOS-FET Power Amp
• Ready for Bluetooth Adapter*
• GIGA MP3 MULTI
• DivX®/WAV/MP3/WMA Compatible (DVD/CD/USB)
• Ready for iPod**
• USB Port
• DTS Digital Out/Dolby Digital/MPEG Audio
• 24-bit Audio DAC
• Digital 7-Band iEQ
• J-BUS Terminal
• Adjustable Line Input Terminals
• Line Output Terminals (2 pairs)
• Video Output Terminals
• Second Audio Output
• Subwoofer Output Terminals with Level/Frequency Control
• Optical Digital Output
• Dual Zone Function
OR
Sony MEX-DV1000
52w x 4 S-MOSFET Power
Front Aux Input
DVD-R/RW/CD-R/RW/VCD/MP3/WMA/JPEG/DIVX Playback
4V Pre Out
13 seg W.LED LCD Display
EQ7 Parametric
SSIR-EXA Tuner
Preset: FM18/AM12
Changer Control
Remote Included
Rotary Commander Optional
Gun Metallic
Detachable Face
Karaoke
Or - if anyone I can find to stock it:
DVH-3950MP
Would like some feedback on the best HU Cheers :thumbsup:
this magic box you speak of... an addition to the setup or a special dvd head unit of its own?
If an addition, how big is it etc? thanks :D
nope.
if you are looking for a magic box - prepare to pay for it. they are available ($400.) - more info - ask me.
If an addition, how big is it etc? thanks :thumbsup:
its in addition and about the size/thickness of a small book. after you have it you can put wahtever DVD unit in. it wont matter.
TV Tuner I was looking at will recieve the PAL signal and output NTSC, so was putting NTSC into the H/U, and NTSC to the screen.
Chris - Can you please recommend me a H/U that has AV line in? seems all of the HU's I posted above DONT have a rear AV input :thumbsup:
so where does it go? behind the scenes, or do you need to make room for it on the facade/dash/console whatever you wanna call it?
thanks
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
