Item: Playstation 3 60GB *Limited Edition*
Age: Brand New
Condition: Brand New
Price: $1200 neg (Sells on ebay for $1350+)
Postage: $50 Express post with insurance or Pick up
Contact: PM Me
Comments: Unwanted prize.
FACTORY SEALED 60gb PAL VERSION PS3
The 60gb model is now no longer available in stores and new consoles will also soon run out on Ebay! The major feature with this unit is Backwards Compatibility with PS1 & 2 Games, which is not offered in the 40gb model.
Whats in the Box
1 x PlayStation 3 console 60GB model
1 x Sony Sixaxis Controller
1 x USB Cable (“A” to “mini-B”)
1 x Ethernet Cable
1 x Composite Cable
1 x Power Cable
A Tax invoice receipt will be sent with the console for you to retain for warranty purposes with Sony Australia.
Don't buy the inferior 40gb version or NTSC or HK version consoles where DVD's won't work and Sony Australia will not warrant if something goes wrong with the console.
Additional Information about Sony PlayStation® 3 (60 GB) Console
Key Features
Console Type Home Console
Platform PlayStation 3
Gaming Type LAN Gaming, Multiplayer Gaming, Online Gaming
Processor
Processor type Cell
Processor Speed 3.2 GHz
Memory
Installed RAM 256 MB
Installed Cache Memory 512 KB
Memory Bus Bandwidth 25.6 GB/sec
RAM Speed 3200 MHz
RAM technology XDR
Display
Max. Resolution 1920 x 1080
Graphics
Graphic Processor NVIDIA RSX
Graphic Processor Speed 550 MHz
Graphic Card Memory 256 MB
Polygons Per Second 75 Million
Storage Type
Hard Drive Size 60 GB
Optical Drive Type Blu Ray
Optical Drive Speed 24x (CD), 8x (DVD)
Audio
Audio Support Dolby Digital 5.1
Audio Out Digital Out (Optical) Connector, HDMI out x 2, Line Out
Technical Features
Communication Type Bluetooth, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g
Expansion Slots Compact Flash (I/II), Memory Stick Duo, Memory Stick Pro Duo, SD Card
Wireless Capabilities Bluetooth 2.0, IEEE 802.11b, IEEE 802.11g
Input / Output Ports 4 x USB, RJ-45
DVD Movie Playback DVD Movie Playback
Other Features
Other Features Broadband Enabled
Regards,
Sarkis
https://www.sau.com.au/forums/topic/216181-playstation-3-60gb-limited-edition/
hahaha limited adition thats funny
So is the warning you just received.
Next time, read the rules and keep your unwanted comments out of other members sale threads.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
