A normal?? :|
I mean for something like this...
Turbochargers have very delicate internal bearings that are subjected to incredible heat and can be damaged within a matter of seconds by small particles in the oil. Talking to specialist turbo suppliers, most turbo failures are due to oil contamination and this is not helped by the fact that your engine oil filter can only filter down to 100 microns.
Our turbo oil filters are precision CNC machined from aircraft quality aluminium alloy and contain a 25 micron stainless steel mesh, greatly increasing the life of your turbo’s bearings. The filters do not require any form of cleaning in normal use, as their large internal surface area will not block even with swarf or particles that have passed though the engine’s main oil filter.
The T0F31 filter is designed for direct fitting to the popular Garrett T3. T35 or T4 turbos and for even greater fitment flexibility the T0F41 filter has -4JIC fittings so that it can be used ‘in-line’ with a replacement Bailey Motorsport stainless PTFE lined turbo oil feed pipe.
We can destroy a turbo for some metal burs!! In a high modify engine it is very propable some metal burs from somewhere in the engine...!
This small think they said that can safe our very very expensive turbo!!
Special in rebuild engines is very propable stay some metals burs in the engine...
Edited by GreeceS13
Do you know the fitting of the HKS?
I have a T04Z turbo... is it easy to fit?
Edit..
I search for it in google but it is only available from nengun and from nitro-performance.com! No many info for this items and also no any feedback! At nitro site they said that it is 1/8PT! Easy to fit in T04Z?
Also there is a copy on ebay.. http://cgi.ebay.com/ebaymotors/TURBO-TURBO...1QQcmdZViewItem
But very identical copy.. and they said that it is from japan..
Edited by GreeceS13
