Item: Cusco Rear Upper Arms
Condition: BRAND NEW
To Fit: R32 GTR
Contact: PM or email (andrewho at au.ibm.com)
Price: $400 SOLD!
Comments:
231 474L Nissan - Skyline BNR32 - +10 to -6mm
FEATURES
- Provides proper camber angle and improves car movement
- Prevents irregular tire wear and holds tire to the asphalt, improving traction.
- The good alignment will enable better traction as well.
- The turn buckle will correct the camber with the change in height.
Item: Cusco Front Pillowball Tension Rods
To Fit: R32 GTR or GTS-4
Price: $340
Comments:
231 473 ASN Nissan BNR32 RB26DET
FEATURES
Reduces the amount of suspension flex during hard cornering.Increases greatly the handling response going into corners by adopting pillow ball mount on the body side. High rigidity pillow rods balls used to hold down tires under braking. Increases straight line stability by reducing toe out and friction.
The turn buckle type allows simple adjustments with the parts on the car.
The pillow balls are covered by rubber boots for increased durability.
Item: Trust/GREX 10-Row Oil Cooler
To Fit: R32 GTR
Price: $950
Comments:
Brand new, only removed from box for photos!
GReddy/GREX Oil Cooler Kits help prolong the life of your oil and in turn your internal engine components. Hard driving causes higher engine temperatures.
GReddy / GREX oil coolers are an excellent addition, and are especially effective in harsh driving environments. By using a similar inner-fin core design as our famous intercoolers, we are able to increase oil capacity, decrease oil temperatures, and extend engine and oil life.
The efficient core and durable steel-braided lines ensure good flow and a leak free installation
  • 2 months later...
  • 3 weeks later...
