Hey all,
When i start or quit a game, i get a static flickering ranging from 1-2 seconds... i get static audio and static visual...
A mate of mine had this with his PS3... and owns the same HD Plasma as i do... but his PS3 is the AUS 40gb ver. and mines the white JP 40gb ver.
Anywho ive tried researching and a few forums are saying its a handshake issue with the resolution from the PS3 to the TV and its "normal", has happened on multiple brands of TV's... well it sorta pisses me off... i didnt buy a PS3 to get static flickers everytime i want to play a game... back on topic... i thought it could just be my mates PS3 that did it, and he was going to return his PS3, but was then advised to try the standard component cables to see if it happened again... he borrowed my PS2 cables and it worked fine, went back to HDMI and hasnt had the problem since...
Ive removed the HDMI cable from both ends and plugged them back in and its still happening... Havent tried the standard component cables yet, will probably try that tonight...
Another mate has the same PS3 as i have and the same HDMI cable (DSE Brand, 1.5m) and he doesnt have any problems with his. so i dont think its the PS3 or the HDMI cable, and ive read on other forums that this happens on a fair few HD Plasmas like some Samsung and Panasonic models, so i dont think it could be the TV either?
Has this happened to anyone else? Can anyone recommend a solution?
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/217046-ps3-static-flickering/
This hand shake you refer to is normal when connected through hdmi. it is the ps3 changing your screens resolution to the games optimal setting. If it is not affecting your gameplay i dont see the prob, there is no damage being done and from what ive been told is that isnt much you can do about it.
The problem is the static.
It might not affect the gameplay, but i didnt buy a PS3 to have static visual and sound everytime i want to play a game, or quit a game...
For a nice, smooth looking system, this static problem sure does affect the experience...
Why does it need to change resolution anyway? ive set it to 720p in the main PS3 menu and the TV setting is at 720p, so what is it changing when going into a game?
Also, just out of curiousity, does the Xbox 360 Elite have this problem with HDMI aswell?
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
