So after recently moving and going from one lot of spares to two lots, we have no room and need to get rid of some stuff!!!
Tyres
No longer needed as I sold my 17" rims - we now only have 18" rims on our cars so they are pretty useless!
One set of four semi slicks - Yokohama Advan A048's - 235/40/17. 80% or more tread left - medium/hard compound. (photos further down in thread)
$385.00
One set of Porsche Cup slicks - 24-64-18.
aka 240-40-18. These are almost completly new. Again used for only one practice session. new tread depth is 3.1mm the LOWEST on these is 2.4mm.
so around 15% worn on average. (photos further down in thread)
$600 a set.(4) ($550 each new)
R33 Stuff
Cusco 6 point Safety 21 roll cage for a R33 Gtst - Steel one, bolt in not weld - decided I can't be bothered and it was a bit of a impulse buy. Bought it off another forum user... its used, ummmm might be missing a couple of bolts from memory but Il replace them before pick up.
$500 ono
Walbro 255L Fuel Pump (GS-342???) ready to bolt into a 33 Gtst.. comes on the std bracket.. ran out of power for my car, prolly did around 4,000 kms over 12 mths..! Was ok at 300+ rwkw but only with the gain turned down on the boost controller
$100 firm
Exedy 5 puk clutch - used for about 3000 kms... hardly worn, couldn't hold the 300rwkw... was fine at 270rwkw though! (photos further down in thread)
$300 ono
Std Flywheel - Just removed from car - twin plate setup reason for removal.
$100 ono
32 GTR SHTUFF
NPC rebuilt OS Giken TS2 twin plate clutch - Basically brand new except the splines are damaged on the friciton plate (riveted hub needs replacing on one of the plates) - push type $500 firm (photos further down in thread)
Gearboxes -
R32Gtr push type - partly disassembled, suits rebuild or anyone chasing a bell housing, input shaft is smashed - although you get all the smashed bits with it :thumbsup: - $250 (photos further down in thread)
R33 Gts-4 push type - 3rd gear is blown, (higher strength, extra ribbed bell housing) doesn't include transfer case - $350 (photos further down in thread)
R32 GTR Bonnet - couple of minor superficial dents/marks... 500 ono - photos next week as the bonnet is stored elsewhere and I need to get there on Monday after Texicana
RB26 Long motor - this will be rebuilt with forged internals, looking at expressions of interest before starting, buyer to have input on internals etc which will vary cost. Please PM your enquiries to Dave aka T04GTR and post in this thread so I can tell him to log on and check it out!!
Random - DR30 Coupe complete doors minus the mirrors, manual wind up windows, red & black trim, red and silver two tone duco - from a RS model. $500 for the pair.
Please PM or post here if interested. Willing to post smaller items, roll cage and tyres etc pickup only unless you can organise your own carrier.
  • Replies 46
  blk180 said:
Im keen on the good semis sould fit my 17*9 rims ok?
Hey Brad,
Yup, I had them on the zeddles which has 9" (well one is 8.5" :) ) rims.... no dramas :rofl:
EDIT: Spoke to Dave before, he used to have them stretched over his 9.5" rims on his GTR
  msnismo said:
[/u]R33 Gtst hard intake: Hard intake for standard turbo or whateva is the same? I have had this HPC'd in a candy blue colour - was on my car when I was still running a hi-flow and AFM... $50 Firm
Do you have a picture of this installed on your car?
I'm curious to know if it will fit on the Stag.
  • 3 weeks later...
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
